Where to mount Eastern Beaver PC-8 in Wee-3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 06-01-2019, 03:56 PM Thread Starter
Martin's Avatar
Hello,
Just looking for some suggestions on where/how to mount an Eastern Beaver PC-8 fuse-box in a 2019 650x. There's not as much space to work with under the seat as there was in my old 2005 Wee.
Anybody just strap it on top of the battery?
- Martin
2019 650X
Martin is offline
post #2 of 5 Old 06-01-2019, 05:20 PM
I put mine right where yours is laying in that pic.
2018 V-Strom 650 XT - Champion Yellow
Rustlr63 is offline
post #3 of 5 Old 06-01-2019, 05:57 PM
Stalky Tracker's Avatar
Ditto. Here's mine.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 5 Old 06-01-2019, 06:31 PM
dmfdmf's Avatar
The previous owner of my Gen2 Wee (2014) put a PC8 in the storage box under the seat. I like to use the storage box for small packages, mail, tools etc that I sometimes pickup on a ride. I dismounted it and left it loose and tucked it in a small gap forward of the battery and the fuses box, relays where it rests on top of the shock. I can't tell if that will work on a Gen3 but you might be able to wedge it down in that hole. Just be sure all the wires are tight and it should be fine. Putting it on top of the battery blocks the seat from locking in.
Next Up: ?
dmfdmf is offline
post #5 of 5 Old 06-02-2019, 05:12 PM Thread Starter
Martin's Avatar
I installed the PC-8 today. I ended up putting it in the tool kit space... mainly because there wasn't enough slack in the heated grips cable to move it any further back.
This meant that the relay and main fuse holders had to be stuffed into the space between the battery and the bike's fuse holder.
It all seems OK but I may relocate the unit further up under the seat so the relay/fuse holder can go behind the battery and the cables don't have to be jammed in around the battery... next time I have tank raised and side cowling off.
- Martin
2019 650X
Martin is offline
