torque specs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 04-21-2006, 02:14 PM Thread Starter
torque specs
Will be installing Givi bars on the Wee in a few days. I have no idea what to torque the bolts to in LB. / FT. Does anyone know offhand what the specs are. Thanks in advance for the info.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #2 of 11 Old 04-21-2006, 06:45 PM
Do you know the size of the bolts? There's a section in the back of the service manual that has general torque specs for various fasteners.
I just installed a set of Givi side racks and had as much trouble as the time I did it on my K5. The bolts they sent are galvanized and tend to cross thread if you look at them wrong. I ended up running the first 1/4" through an 8x1.25mm die to clean the threads up.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #3 of 11 Old 04-21-2006, 10:20 PM
Heavy's Avatar
Re: torque specs
Hey WW. I just finished installing my Givi's on my V. I don't know if yours uses the same mounting bolts but this picture might help.
And the torque for each bolt is in the following chart.
I'm kind of surprised as the torque values for the 650 are considerably higher than those for the 1000.
You might look at downloading a service manual for future reference too.
http://www.tpgtex.com/calsci/DL650K4_svc_man.pdf
Heavy is offline
post #4 of 11 Old 04-22-2006, 12:55 AM Thread Starter
TomG
Heavy
Thanks guys, the hints and info should do the trick. Just have to finish up a bit of wire tie down work on the driving lites and the bars are next. A real bonus, the lites even worked the first time and no blown fuses. Tomorrow will be warmer so the Bat Cave will only be dark, not dark and coolish.... Ride On Guys.
05 / 650 in blue
75/Suzuki 125 RV
post #5 of 11 Old 04-22-2006, 09:57 AM
Heavy's Avatar
Why is it that every time you talk about working on your Strom in "the bat cave", I envision you wandering down there in a pair of comfy old house slippers?? :lol:
Heavy is offline
post #6 of 11 Old 04-22-2006, 11:39 AM Thread Starter
Heavy
Dream on Heavy. Size 12 EEEE width and Arch supports. New Balance sneakers work well. Wish they made riding boots too. I usually wear work style cowboy boots, looked at dedicated riding boots but the cost factor and availibility was pretty hard to justify. ......Hmmmm, Bat Cave, dark, warm, outside, bright, warmer, fresh air, two wheels freedom no flashlites freedom. ARRRGH ! ..Note to self: go to bat cave, STAY.
05 / 650 in blue
75/Suzuki 125 RV
post #7 of 11 Old 04-22-2006, 07:31 PM Thread Starter
OK, I'm done for the day. Driving lites finished after I discovered and corrected a flaw in my wiring. Being hunched over feeling around in a dark fairing is hard on this old body. Tomorrow, Givi bars. Farkle On.
05 / 650 in blue
75/Suzuki 125 RV
post #8 of 11 Old 04-23-2006, 08:25 AM
Vordak's Avatar
Location: Eastern Ontario, Canada, Earth, Solar System.
Farkle
Well, aren't we all farkled!
Never Argue with an idiot, first he'll bring you down to his level, then he'll beat you with experience...
1986 FZX750R Fazer-Should've never sold it!
1986 BMW K75-Old smoker! Good bike. Sold.
2003 DL 1000 Bumble Bee, farkled! Sold.
2006 Honda Goldwing Navi AL.
Vordak is offline
post #9 of 11 Old 04-23-2006, 08:30 AM
Heavy's Avatar
Maybe you should find a comfy chair, sit down, put your feet up and take a break. I hear good therapy is reading the manual for a new digital camera. Takes your mind off the pain and allows you to record the results of your farkling.
(pics of the lights?)
Heavy is offline
post #10 of 11 Old 04-23-2006, 05:14 PM Thread Starter
Heavy
I would rather read the forum. It is much more interesting. But I did open the box and put the batteries in the camera, that is a good start.... WHAT ME HURRY ??
05 / 650 in blue
75/Suzuki 125 RV
