DL650 Wheel Compatibility - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Stromwulf
post #1 of 4 Old 04-10-2019, 01:35 AM Thread Starter
Hey guys, hoping someone can shine some light on wether or not I can do a straight swap with my 3 spoke cast wheels for some spoked ones? My bike is a 2016 Dl650 & I am looking at replacing the 3 spokes with a pair of spoked tubeless wheels off a 2018 Dl650 XT, I am guessing the spacing will be the same as the fork & swing arm & brakes 'seem' identical, however I read about speed sensor placement been different between cast & spoked? Any info muchly appreciated!
Stromwulf is offline
post #2 of 4 Old 04-10-2019, 01:48 AM
jgendr's Avatar
your problem is not going to be fitment and the tone rings are for abs only not speed sensor. the speed sensor is on the front sprocket.
the [problem your going to have is finding the spokers. very pricey and those that have them tend to keep tight hold on them. if your lucky enough to find a set the question is can you afford to buy them. There is an aftermarket manufacturer but a set starts somewhere close to 2k US.
2014 DL650 VStorm
jgendr is offline
post #3 of 4 Old 04-10-2019, 02:25 AM Thread Starter
Ok so they should fit fine? Thats good news!
post #4 of 4 Old 04-21-2019, 02:59 AM Thread Starter
Just thought I would answer my original question & confirm that the new DL650XT wheels will fit on 2012-16 650 'Stroms, bolt straight on & the sprocket carrier can be swapped between the cast & spoked wheels also which is handy. Oh & they look SWEET! Cheers
andrewsw likes this.
Has Owning My DL650 Saved Money ? XLonDL650 General V-Strom Discussion 48 09-10-2018 11:23 PM
Speedometer compatibility between DL650 and DL1000 dchooo DL650 and DL650A - 2004 to 2011 3 03-12-2015 01:32 PM
2012+ DL650 front wheel removal NeverSatisfied Maintenance How-to 2 07-12-2014 01:13 PM
SV650 front wheel installation on a DL650 exploring/carolina V-Strom Modifications and Performance 53 06-12-2014 02:54 PM
V-strom dl650 wheel nedodjija General V-Strom Discussion 5 09-16-2011 09:13 PM
