Folding Brake Pedal Tip......... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 11 Old 04-06-2019, 08:15 PM Thread Starter
I performed this same "graft" onto my little CB500X a few years ago. Fortunately, it was never put to the test (i.e. I never laid the bike down to test if it folded out of the way). Installed on my WeeStrom today. The folding tip comes in different colors......look for them on Ebay and Rocky Mtn ATV......about $20........cheap mod. (I have the $30 Studebaker folding gearshift pedal on the other side).
Basically cut off the OEM "tip", grind smooth, drill one M6 hole, bolt up. NOTE: my new tip had a "ridge" running down the inside flat portion that rest on top of the OEM brake pedal arm.....I cut the ridge down with a Dremel.) The triangular pedal folds "back" and towards the bike when dropped. Time will tell how well it holds up.......
www.easternvstromrally.com
mark444 is offline
post #2 of 11 Old 04-06-2019, 08:18 PM Thread Starter
More pics..........
....more pics.............
Gert likes this.
mark444 is offline
post #3 of 11 Old 04-07-2019, 03:15 AM
Rolex's Avatar
It is not easy to do on a strom but I also fit what has become known as a brake snake.
My dad built them for all my dirt bikes when I was growing up, he used old brake inner cable and electrical connectors to loop around the frame, the wire stops the brake or gear leaver being bent right back ensuring the ride is not spoilt with a unusable leaver.
I know that one time that I dumped my Wee the brake snake saved my brake leaver enough that I could continue.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 11 Old 04-07-2019, 07:51 AM Thread Starter
Funny you mention that, Rolex. The folding tip I purchased actually CAME with a cable (brake snake?), bracket (to use at an engine bolt location), and cable crimp, so one could add this along with the folding tip.
I always thought the cable thingie was to prevent sticks (shrubs) from getting caught between the pedal and frame.......
DesertBike likes this.
mark444 is offline
post #5 of 11 Old 04-08-2019, 12:15 PM
vanislejay's Avatar
Can you post up some pics of this?
2003 DL1000
Too much other broken stuff to list
vanislejay is offline
post #6 of 11 Old 04-08-2019, 04:06 PM
Onboard Mass Damper
DesertBike's Avatar
I think I know what he's talking about. It's a cable running from the brake pedal to somewhere on bike frame. I was under the impression they were mostly to keep brush from getting wedged between engine and lever, when riding in rough stuff. Dunno if such a cable would keep the lever from getting bent back in a slide, but it couldn't hurt.
I could tie the forward end to my crash bars or skid plate, probably.
Love the springloaded brake pedal. Could use something like this for the shifter too.
2007 Vee
DesertBike is offline
post #7 of 11 Old 04-08-2019, 04:45 PM
larolco's Avatar
Install one of these and you are guaranteed never to lay the bike over (on that side).
DRZ400SK17
larolco is offline
post #8 of 11 Old 04-08-2019, 06:20 PM
Onboard Mass Damper
DesertBike's Avatar
Correct. Same way I have never had a flat tire on my car since I started carrying an actual floor jack in the trunk.
I've probably spent the cost of a new tire in gas hauling that thing around, but the jack supplied with the car is just wayyy too junky for my tastes.
2007 Vee
post #9 of 11 Old 04-09-2019, 09:08 PM
Motor7's Avatar
Mark, do you have a link?...only one I see on fleabay is $59.99.
'15 DL650XT
Motor7 is offline
post #10 of 11 Old 04-09-2019, 10:54 PM Thread Starter
Folding Tip..........
Well crap, Motor........I cannot find the one on Ebay that I saw last week. I ordered mine from "OpenTip".....$21.95, but then they ripped me a new one with $6.00 shipping. When it arrived, it was in a $3.75 First Class Envelope.......I cannot recommend them.
Rocky Mtn ATV has them, but not in Black........Tusk series
https://www.rockymountainatvmc.com/p...ment-toe-tip-p
Warp9 makes them...........
https://motoxindustries.com/product/...g-brake-pedal/
mark444 is offline
Rear Brake Pedal Mod Considered Oldad General V-Strom Discussion 0 06-13-2018 10:26 PM
Brake cylinders poorly retracting Nikolay.Karushev DL650 and DL650A - 2004 to 2011 18 11-27-2017 09:20 AM
Folding Brake Pedal (the other side) Violione DL650 and DL650A - 2004 to 2011 7 10-28-2009 02:03 PM
bent brake pedal jonl General V-Strom Discussion 2 08-16-2009 09:57 PM
Front brake line problems... bubbabob DL650 and DL650A - 2004 to 2011 26 10-30-2008 11:47 PM
