Fork cartridge - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By pete4x4
post #1 of 7 Old 03-27-2019, 08:36 AM Thread Starter
Hi. Like most of us I think that the Vee is little on the suspension side.
At 230 lbs the front dives when braking and the damping adjustability is near inexistent( full in to full out some light changes)
I was looking to go with stiffer spring and gold valve kit. All ready go that way on my FZ09 with Stoltech( specializes in fz-09 mods).
But from the reviews from other Vee owners. The set-up from RT isn't quite it. And need some adjustement...taking the fork in pieces 2-3 times. Which is time consumming...and not to mention I don't have a garage I do all my mechanic outside.
For that reason I was leaning toward a full cartridge replacement. Fast easy fix ..but a little pricier...depending on the cartridge I would go with.
My question is have some of you guys changed the cartridge in your fork?. And which one? Pros and cons?
I've found Andreanni, Matris and Traxxion dynamics.
From the cheapest to the highest priced.
I have a 2018 vstrom 1000xt.
DesertBike likes this.
2018 Vstrom 1000 XT yellow stinger
pete4x4 is offline
post #2 of 7 Old 03-27-2019, 11:40 PM
I bought the Matris kit a couple of years ago and it was $500. It works very well though I only have about 500 miles on it. I had a
problem of topping out which is my fault for leaving the short spring out (the one which sits on the bottom of the fork). Have not been able to ride or work on bike to fix that for over a year but it did work great. Well set up from the factory and adjustments are
easy. Would do again in a heartbeat.
NH Charlie is offline
post #3 of 7 Old 03-28-2019, 08:55 AM
RichDesmond's Avatar
Give Jamie at DMr a call:
DMr Performance Suspension ? DMr Performance Suspension ? world leader in engineering and manufacturing performance motorcycle suspension systems
Rich Desmond
RichDesmond is offline
post #4 of 7 Old 03-28-2019, 10:36 AM
Hey Rich, which spring type is best "in your opinion and experience" and why? Local racer and moto mechanic "Ryan Kerr" isn't a fan of straight rate springs when he builds suspensions, you are a fan of straight rate, so just curious as to why and when to use either.
post #5 of 7 Old 03-28-2019, 07:59 PM
JustAnotherDude's Avatar
Both great write-ups. Costs are included.
Cartridge replacement (Motocanada):
https://www.stromtrooper.com/dl1000a...geupgrade.html
RaceTech/spring build (Berksglh):
https://www.stromtrooper.com/dl1000a...race-tech.html
JustAnotherDude is offline
post #6 of 7 Old 03-28-2019, 08:56 PM
My 2 cents:
Sonic Springs: Straight rate vs progressive rate
Rich Desmond
post #7 of 7 Old 03-29-2019, 08:19 AM
Originally Posted by RichDesmond View Post
Awesome thank you sir, and that makes total sense.
Cartridge fork upgrade options other than Traxxion (Matris, Andreani, donor) J58943 DL650 and DL650A - 2004 to 2011 19 02-11-2018 06:37 AM
Possible to adjust front suspension on a DL1000 K2? Halisko DL1000 from 2002-2012 10 08-09-2017 02:31 PM
Installing Racetech Springs with Gold Valve Emulators on 650 lacofdfireman Suspension and Tire Tech 18 11-23-2016 07:13 AM
Fork seal change CaliScott V-Strom Service and Maintenance Questions and Discussions 3 05-22-2016 12:57 PM
Fork oil height/sonic 1.1 springs hunt1moore DL1000 from 2002-2012 16 09-22-2014 07:23 AM
