VEE Power commander Canadian vendor?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 02-17-2019, 02:50 PM Thread Starter
Back on a VEE....just picked up a really clean 07 all stock.
Going to do a Power commander and dual cans just like my last VEE which was a 06.
I used PCV then.
Is the new PCFC a good go?
Whats the difference between the PCV and PCFC?
Thanks all
2007 VEE
Delkevic pipes, PCV
drewda is offline
post #2 of 2 Old 02-17-2019, 04:44 PM
The PCFC does everything just like the PCV for our bikes. The V has some cool features if you are a road racer or drag racer, like automatic shifting with a pneumatic shifter, stuff like that which we don't need at all. Tuning wise, the FC is as good or better than the V. You can tune it to a particular mixture every 200 rpm. The same programs work on both. I had my modified '06 Vee, like you used to have, done on a dyno using the FC and it runs great!
bobbyvstrom is offline
Remapped Power Commander USB on the 2005 Vee! bruinVSTROMguy Maintenance, Tech and Products. 0 12-04-2017 01:04 PM
Turn off power Commander? domromer General V-Strom Discussion 10 04-29-2013 01:59 PM
Manual Power Commander settings for 04 DL1000 with Two Bros exhaust? Vincenthdfan DL1000 from 2002-2012 13 02-18-2013 07:53 PM
Power Commander Map for the DL650 Akrapovic Slip On Exhausts SV Racing Parts SV Racing Parts 9 01-31-2013 01:03 PM
power commander help sokol DL1000 from 2002-2012 6 12-29-2012 10:49 PM
