2013 650 Outback Motortek Center Stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-10-2018, 02:26 PM Thread Starter
Outback Motortek Center stand V Strom 650 2016
I bought a center stand from Dualsport Plus on September 5.
I tried to install the stand but the plate numbered 6 on the installation guide (attached) was no properly machined. (See attached). Then I discovered that bolts labeled 12 and 13 did not fit the center stand. They're machined bigger than the stands attachment points. I contacted both companies with 2 different results.
1. Dualsport exchanged the part and listened to my problem with the bolts.
They gave me a discount and I elected to make it work.
2. Outback Motortek told me I’m wrong and it’s actually the right part. See photos attached and makeup your own mind.
I used a drill, file and sand paper to make the Allen bolts work. Took about 30 minutes. Then I tried to install the center stand to discover that a bolt on the Suzuki is in the way. Remember that I already exchanged this part for the correct part. I had to cut a piece out (see attached) to make it work. The instructions was very “low keyed” to say the least.
My problem is the following. The company claim to be based on proper PR, engineering and quality control. I contacted the company via web pages and 5 days latter they did not even told me to get lost. The parts and initial quality control were poor. The PR that I got blamed me for the mistake and then just ignore me.
But the good news is that it’s working and fits properly after modifications. High up and tucked close to the bike. I hope it last as I bought this based on reviews from other users.
File Type: jpg 149cabdb1bf69a1fcda203d76269f6bb.0.jpg (186.9 KB, 10 views)
joeslabb is offline
post #2 of 3 Old 09-10-2018, 09:12 PM
Jeepster09's Avatar
No installed pictures?
Jeepster09 is offline
post #3 of 3 Old 09-11-2018, 04:22 PM Thread Starter
Up loaded again
File Type: jpg 149cabdb1bf69a1fcda203d76269f6bb.0.jpg (186.9 KB, 5 views)
joeslabb is offline
Center stand + front stand OK? skyguy Maintenance, Tech and Products. 13 09-21-2018 08:10 PM
Suzuki center stand just bent Bugzy DL1000 from 2002-2012 30 05-07-2018 05:58 PM
Easiest Center Stand to Install Numbercruncher DL1000A - 2017+ 17 04-14-2018 08:43 PM
Rant about Happy Trails Center Stand and service Larry33319 Product Reviews 25 08-02-2014 11:59 PM
