Bar swap and remounted original bar ends/hand guards - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 3 Post By NorthBay94928
post #1 of 3 Old 08-17-2018, 12:13 AM Thread Starter
I just installed a new set of Pro Taper Contour fat bars. I was not ready to drop another $150 on Bark Buster Storms so I found an easy way to mount the original ones in the smaller diameter Pro Tapers.
I had read about drilling them out but it looked like it would take too much material away. I have so been cruising the hardware store looking at drywall and concrete anchor options.
So I looked in the parts bin and found a long nut and bolt and fuel hose. I just ran the bar end and spacer, then a bit of fuel hose and the new flared nut and jammed it into the end of the bars and it tightened right up.... I guess the friction of the hose held the nut in place. I probably should have added a washer but the nut was flared and holds really well.
Since a picture is worth a thousand words, see the 2 pics below.
thirdofthree, jcs and Jeepster09 like this.
NorthBay94928 is offline
post #2 of 3 Old 02-18-2019, 09:51 PM
Just tried your bar end swap on my new ProTapers and it worked spot on.
Thanks for taking the time to get those photos on there. Helped out a lot.
papi is offline
post #3 of 3 Old 02-19-2019, 09:09 AM
eff
eff's Avatar
Actually some aftermarket hand guards come with a set up just like you came up with. For best results use locking flange nuts with the serrations one the bottom to bite into the hose.
2007 V-Strom 650
2004 GasGas EC250
eff is offline
