My Sixfitty crashbar bash plate project. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 04-14-2006, 11:30 AM Thread Starter
Sorry for the length.
I'm done for now. :P It's not ideal but a start and after going through this excercise I already have many changes I want to make. The front oil cooler guard was the most hurried as the weather is nice so I rushed to get the bike back in service. I was going to use a heavier gage stainless steel screen in the place of this which would have made the whole grill visually nicer. But.....
FWIW in my projects, function is more important than looks/beauty. Obviously :P
Design goal: Protection of engine cases and oil system from rocks, sticks etc. I've encounter problems previously with both. Stick wise I don't think anything will get through now as this is one of my biggest worries out in the woods.
Originally I was going to re-locate the oil cooler vertically and higher on the left side of the engine. I scraped that and put more design into the full protection system.
No provisions were made for oil/filter changing. It comes off pretty easy for now, and I usually do some cleaning and inspection when this gets done anyways. I may in the future add this feature.
If I were to make more I would go up in tubing size and wall thickness, bend it and make and cut patterns for the pan.
Specifics:
Psuedo/simple crash bar tubing is "double barrel" stainless steel .75"OD x 20 gage(.035") wall. I used this because I got it at a really good price. The thin wall was the reason I doubled it up. It's very stiff esp with it all boxed together and tied to the plate and the narrow front profile is clean aerodynamicly. It's also suprisingly light weight. Frame mount plates are aprox .10" and all other brackets reinforcements etc are either 16 or 18 gage.
The Plate is 3003 .125" aluminum. Again this was chosen for its price and availability as I actually had to pay for this stuff. I may reinforce it if needed and also might make a fittted lift plate for maintenance etc. Their is a cut out for the flattened exhaust crossover tube underneath to keep ground clearance as high as possible.
Tankified
My second annual spring project is done!!
Time to ride.
sideways and smiling
WIsixfitty is offline
post #2 of 10 Old 04-14-2006, 08:59 PM
I like it! Looks tough and kinda futuristic! I'm sure it feels good to fab something yourself instead of just buying it (like I did ).
stlrmike is offline
post #3 of 10 Old 04-14-2006, 09:17 PM
Hey WIsixfitty, how come your front exhaust pipe is all shinny and new looking? Mine is all bluish and brown from the heat.
Nice job on the crash bars and engine guard, it looks great!
'06 DL1000 - Grey
'89 GSXR 1100
'85 GS550E (Suz)
'75 Yamaha MX250B
'73 Yamaha MX125
Keep your feet on the pegs and your hand on the throttle.
ChrisW123 is offline
post #4 of 10 Old 04-14-2006, 09:35 PM
Nice work and fabrication......but it looks like a SERIOUS pain in the ass to get to your oil filter now! :?
Big B is online now
post #5 of 10 Old 04-15-2006, 12:41 AM Thread Starter
Thanks.
I just re-polished the complete exhaust system. Since it's stainless and I have polishing wheels it's not too hard.
Yes getting to the filter and drain is more work. But this is not a big priority as I will just take it off to clean and inspect the bike at that time. I can have it off in just a minute or two.
post #6 of 10 Old 04-15-2006, 03:16 AM
Nice fabrication to protect all the important pieces. Two ??? Is there much of a weight penalty with all the SS and aluminum and secondly is that a storage unit where the muffler used to live ??
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #7 of 10 Old 04-15-2006, 06:54 AM
Bravo! Great job mate, looks very neat and professional. I'll take a guess you come from a metal work background?
DL650 K5, Staintune pipe, topbox, Powerbronze bellypan, Givi E21's, Suzuki handguards
Barney is offline
post #8 of 10 Old 04-15-2006, 11:38 AM Thread Starter
Yes it is a water tight storage unit I did as my last springs project.
The stainless is very thin wall (.035"). I will weigh it the next time I have it off. I would estimate it's around 5 pounds.
Thanks Barney and yes I do that sometimes as my day job too. :P
post #9 of 10 Old 04-15-2006, 10:34 PM
dmf109's Avatar
I like it! Your crash kit looks like the bike designer himself added it! Very good job. You wouldn't happen to be posting specs soon, or do I have to fit/cut/fit it all myself?
dmf109 is offline
post #10 of 10 Old 04-20-2006, 10:17 AM Thread Starter
I've listed the material specs. It sounds like you want drawings. Correct?
I'm not sure I want to give away my drawings but....
