Stebel Install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 04-14-2006, 12:33 AM Thread Starter
Send a message via AIM to Trooper246
Stebel Install
After reading the long thread on the other V-Strom forum for this install and armed with Peter's wiring diagram, I tackled the install today. I don't know how you guys do this in 15 minutes cause it took me a couple of hours.
I decided to remove both side fairing pieces so that meant have to remove the engine guards also. While I had these off I repainted them. I also noticed areas of rust on the light bracket so while I was in there I painted these areas too.
I mounted the horn on the left inside fairing using a hose clamp on the bottom and tie wrap on top. I also glued a piece of foam on the horn so that it was cushioned on the bracket.
I found the stock horn and was able to remove the connectors by hand after removing the sensor from the radiator and pushing the shroud back a little. I pulled the wire back and made the connections on the right side.
I wired the power into the fuse box and ran a ground back also.
The relay was mounted on top of the radiator shroud but I plan on moving this to either the tank or inside fairing using dual-lock. Right now it is on with industrial hook & loop. The photo is out of focus but you should get the general idea.
Everything worked fine on the initial test so I buttoned it all back. Sounds great.
Thanks for all of the help in the first thread.
Steve
Stephen, V-SRI 027
[url]www.caferacerpodcast.com[/url]
13 Moto Guzzi Stelvio NTX1200
13 Triumph Tiger 800
02 Moto Guzzi V11 Tenni
07 ST1300 (traded)
03 Bandit 1200S (crashed)
02 V-Strom (sold)
Trooper246 is offline
