fork-mounted LED cop lights = ultimate running lights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 25 Old 06-23-2009, 09:12 PM Thread Starter
The Golden Monkey's Avatar
Lightbulb fork-mounted LED cop lights = ultimate running lights
I liked the extra light on the road provided by the driving lights I had on my last strom, but to be effective without blinding oncoming traffic, driving lights need to be mounted as high as possible. On the strom this is close to the headlights, which doesn't help conspicuity much since the bike's lighting profile is still just a (larger) apparent single blob of light.
Since I got the new wee last fall, I've been planning to add some running lights for visibility. Ideally that means the lights should be down low for the "triangle of light" effect, and yellow or amber since those colors are more noticeable in traffic than standard halogen or HID bulbs.
Fog lights can be down low, but I haven't been able to find any yellow bulbs that aren't 55W or more. I know you can get MR16 or MR11 lights with yellow 20W bulbs, but I figured if I was going to have lights that didn't put much illumination on the road, I wanted them to use as little power as possible, so LED is the obvious choice.
I wanted something brighter and with a larger face than the available standard-base LED bulbs. I figured I would use the Whelen LIN3 or TIR3 lightheads as several others have, until I found the Nova SLMINI. It's cheaper than either of the Whelens, entirely sealed and self-contained, and only 1/3" thick. They're bright as f&ck but only draw 0.5 amp each.
I made brackets from 3/4" x 1/8" aluminum bar stock, and painted them and the back of the lightheads black to blend in better with the forks and fender.
I got some longer bolts to replace the fender bolts and mounted the brackets there. (Now I wish I had rounded the corners of the bracket for a more finished look.)
I bundled the wires with the speedo and ABS sensor wires on the fork, then they run back to the fuse block under the seat. I wanted to use posi-locks but didn't have any of the waterproof kind, so I wrapped the whole connection in shrink tubing.
The finished product:
CAN YOU SEE ME NOW DAMMIT?!?
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
post #2 of 25 Old 06-23-2009, 09:57 PM
av8or's Avatar
Send a message via AIM to av8or Send a message via Yahoo to av8or
red ones would make great brake aux lights with the flashing
[COLOR=Blue]'07 Suzuki DL1000 V-Strom[/COLOR]
av8or is offline
post #3 of 25 Old 06-24-2009, 09:31 PM Thread Starter
Yeah, if I ever get aluminum panniers I'll put one on each as extra brake/tail lights.
2009 DL650A - sold
post #4 of 25 Old 07-18-2009, 08:14 AM
Ducman69's Avatar
One word: WIN!
[URL="http://www.youtube.com/user/DumbDuck44"]Duc's WeeStrom Vlog[/URL]
Ducman69 is offline
post #5 of 25 Old 07-18-2009, 08:34 AM
Ducman69's Avatar
Questions:
Can these be synchronized on the flashing? I believe flashing amber is legal, as long as its a regular non-alternating pattern, right?
Be nice to have em steady on but w/ a switch somewhere so I could get em flashing if needed, but flashing together.
And on the tail-lamp, any idea what is needed for these to mount to my Pelicans? I assume you'd need some relay deal and I thought they'd only be legal for flashing if they eventually go solid red, right? Although I suppose one could get by on this if they are usually off and only flash on brake.
$90 for 2 plus $8 shipping the cheapest y'all have found?
Ducman69 is offline
post #6 of 25 Old 07-18-2009, 08:42 AM
SRT
Nice!!!
Great install too.
SRT is offline
post #7 of 25 Old 07-18-2009, 10:35 AM
Dntouch's Avatar
So the guy in the video says that they have a "steady burn" also. ? Is that one of the patterns and do you have to program it everytime the bikes ignition is turned on?
Very good solution for being seen.
Dntouch is offline
post #8 of 25 Old 07-20-2009, 11:15 PM
I purchased one for an additional brake light. It should get here on Thursday. If I can figure out how, I'll post a video when I'm done.
The instructions for setting the strobe pattern are on the bottom of the wiring instructions.
Can be seen here. http://www.strobe.com/support_docume...ALL-SLMINI.pdf
Here is a list of the options for patterns.
# Flash Pattern Description
1 Steady - ON All LEDs on. FOR USE WITH EXTERNAL FLASHER ONLY.
2 RANDOM - Randomly selects from patterns 3 through 8 and runs each pattern 10 times.
3 Double Flash - 2 Flash Bursts. All LEDs firing.115 Double Flashes Per Minute.
4 Quad Flash - 4 Flash Bursts. All LEDs firing. 140 Quad Flashes Per Minute.
5 Mega Flash - 1 Flash Burst. All LEDs firing. 500 Flashes Per Minute.
6 Phased Mega - 1 Flash Burst. All LEDs firing. Varies from 360 to 1200 Flashes Per Minute.
7 Deciblast - 10 Flash Bursts. All LEDs firing. 170 Deci Flashes Per Minute.
8 Flasher - Wig-Wag Flasher pattern. 3 Flashes per second flash rate.
Hope this helps,
RW
RackWrangler is offline
post #9 of 25 Old 07-21-2009, 02:41 AM Thread Starter
Thanks everyone, I'm pretty pleased with them.
I have them set on steady burn. You step through the flash patterns by applying power to a third wire. It retains your setting until you power that wire again. I set them to steady burn, then cut most of that wire off, since it's very unlikely I'll want to use the lighthead's built-in flasher. If you want to use them as turn signals/hazards, the bike's signal flasher is the best way to control them anyway.
2009 DL650A - sold
post #10 of 25 Old 07-21-2009, 02:52 AM Thread Starter
Originally Posted by Ducman69 View Post
Questions:
I don't think using the built-in flash patterns would be a good idea, except maybe in red as a flashing brake light. The flash patterns are so distinctively police/fire/ambulance-style, they would probably be confusing for other drivers.
They could certainly be used as turn signals, simply set them to steady burn and patch them into the signal wires. You could put a switch inline that toggles between steady power (for running lights) and the turn signal wires. And I'm sure someone who knew what they were doing could create a circuit to do that automatically whenever the turn signals are switched on.
To use them for flashing brake that goes solid, you'll need a controller of some sort, but not a relay. You could just choose one of the built-in flash patterns and wire them in with the brake lights. I believe continuous flashing brake lights are legal (except maybe in California), but that would get pretty annoying for anyone behind you in traffic. Did I mention they're really bright? I think setting them on steady burn for simple aux brake light(s) would be fine.
They were only $40 each when I bought them at a special introductory price. I haven't seen them anywhere else, but then I haven't been looking either...
2009 DL650A - sold
Tags
led , lights , visibility
