ABS disconnect? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-08-2018, 11:54 PM Thread Starter
Headintheclouds41's Avatar
ABS disconnect?
Aloha yíall!
Iím a newbie to the forum and hoping someone can tell me an easy fix to disconnect the ABS of my 650xt. Iím an experienced off road rider and feel more comfortable being able to lock up,the rear when needed. Hopefully, itís just a matter of pulling a fuse. TIA!
Headintheclouds41 is offline
post #2 of 9 Old 05-09-2018, 12:38 AM
marcham's Avatar
Do you have a centerstand? Start the bike, spin one wheel and voila! Disabled until the next start.
Sent from my SM-T700 using Tapatalk
2015 VSTROM 650 X ABS EXP
marcham is offline
post #3 of 9 Old 05-09-2018, 12:44 AM
Pull the fuses or buy an abs disconnect kit from Easternbeaver, unless it’s a 17/18 then I believe you’re out of luck on the kit.
1997 Honda Valkyrie 1500 custom ďDoloresĒ
post #4 of 9 Old 05-09-2018, 06:14 AM
scootac's Avatar
If it's as easy as pulling fuses, why would anybody develop/build/buy a disconnect kit?
Does the kit do something besides disabling the ABS? Maybe a switch to it on/off from the seat?
scootac is offline
post #5 of 9 Old 05-11-2018, 05:00 PM Thread Starter
Mine is a Ď17. A glance under the seat didnít reveal any fuses marked ABS. Where is the ABS fuse located on a Ď17? Donít have a centerstand...........yet.
post #6 of 9 Old 05-14-2018, 09:41 AM
Motor7's Avatar
There is a recent thread where a guy located the active wire at the abs plug under the seat, cut the wire and added a momentary switch up on dash. Total cost might have been $5.....I'll see if I can find it.
'15 DL650XT
Motor7 is online now
post #7 of 9 Old 05-14-2018, 10:10 AM
Motor7's Avatar
https://www.stromtrooper.com/dl650a-2...onnection.html
'15 DL650XT
post #8 of 9 Old 05-14-2018, 07:30 PM Thread Starter
Great info in that thead! For now I’d be happy to just pull the fuse until I do the switch mod. Now I just need to find the right fuse.
post #9 of 9 Old 05-21-2018, 01:02 AM
Hi there - I am looking to buy a 2017 650XT - any results yet on figuring this out? I'd like to know before I buy...
maddiecycle is offline
