6 piston - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-13-2009, 09:18 AM Thread Starter
6 piston
Does anyone know of a six piston set up that would plug and play on a DL 1000 ?
Has this been discussed before?
GrasshopperII is offline
post #2 of 9 Old 06-13-2009, 10:05 AM
bill l's Avatar
There are adapters for Tokico 4 pot calipers, haven't seen a six. I just put the 4's on my 650 and the difference in feel is well worth the effort.
64 Hon cub 50, 67 Hon trail 90, 68 Yam 180 twin, 66 Hon 305 dream, 71 Yam 175 enduro, 73 Yam tx500, 70 Hon sl100, 75 Hon xl250, 79 Yam sr500 , 95 Kaw en500, 98 Hon cb750, 02 Yam fz1, 06 Suz dl650, 07 Hon ST1300
Avatar:
https://www.stromtrooper.com/forums/a...4&d=1170279743
bill l is offline
post #3 of 9 Old 06-16-2009, 10:40 PM
PDXDave's Avatar
I'm running the same setup and if you ad a large bore master cylinder to the mix, the improvement is half again what the four pot calipers do. I used a 02 cbr 954 master and it was almost a direct bolt on, just a little dremmel work to square off the counter sink on the pivot bolt.
The six pots youre thinking of came on tlr's and some late 90's gixxers. They are OLD tech and the newer gixxer four pots are a MUCH better caliper.
D
The above post was written on a worn out, porn filled computer by a meanspirited, evil, pissed off bikersnob. It contains absolutly no usefull information and was created entirely to mislead and confuse you.
PDXDave is offline
post #4 of 9 Old 06-19-2009, 08:32 PM Thread Starter
Hey guys,
Thanks for all the info.
I will have to look into it.
post #5 of 9 Old 06-22-2009, 05:30 AM
Lesman's Avatar
6 piston tokico stuff came from advrider
Lesman is offline
post #6 of 9 Old 06-22-2009, 05:36 PM Thread Starter
Thanks lesman, I will search it out.
post #7 of 9 Old 06-28-2009, 08:20 AM Thread Starter
Soooo, after searching this out, seems like you were a part of this if you use the same name on the other site.
Wher can one purchase this bracket, anyone mfg. and selling them at all?
Is it a take this diagram and have one made at a machine shop kind of thing.
Rather just purchase one.
post #8 of 9 Old 06-28-2009, 01:56 PM
lectric's Avatar
SVRP
Check with Blair at SV Racing Parts. He carries some of them for other swaps. here is his contact info http://stores.ebay.com/SV650-Racing-Parts
[email protected]
lectric is offline
post #9 of 9 Old 07-05-2009, 11:48 PM
Lesman's Avatar
You are confusing my GSPD(6 Piston Tokico)with the Strom(4 Piston Tokico).Buy Blair's stuff.
Pads, Bracket's and calipers are $200-$300. I had the Flu. I did the whole change out in 2+hours. It really should not take more than 1 to 11/2 hours.
Les
Lesman is offline
