Modulating Led head light - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 04-11-2018, 12:52 AM Thread Starter
I'm new to the forum and searched for this, so forgive me if it has been asked.
I'm going from a 2004 vstrom to a 2012 vstrom adventure. My question is that the 2012 has a modulator for the headlights already installed with stock headlamps. I am wanting to install LED headlamps. I am unsure of the brand of modulator on the new to me bike and was hoping to order the headlamps before I tear into getting under the cowling. Will modulating be hard on the LEDs. I've searched a few of the companies that make the headlight modulation kits, and they don't specify a lamp type.
Thanks for any info.
Dyoung1987 is offline
post #2 of 2 Old 04-11-2018, 02:40 AM
Clayyalc's Avatar
The modulator isn't going to work with most LEDs. Most LED's have some sort of voltage regulator system and can take 9-32 volts. The change in voltage isn't going to change the brightness. If the voltage drops below the input range most just shut off.
2015 DL650
Clayyalc is offline
