Lowering Forks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 03-05-2004, 04:15 PM Thread Starter
Lowering Forks
I'm putting my bike back to stock height in the back. How much should I raise the forks in the tripple clamps?
Scooter
scooter is offline
post #2 of 8 Old 03-06-2004, 09:30 PM
dbl_aitch
To where the caps are level with the top of the upper triple clamp.
post #3 of 8 Old 03-06-2004, 11:43 PM Thread Starter
Drop
I like my bike dropped in the front. This puts more weight on the front tire making for a safer ride. The bike can get very light in the front when it is fully loaded for touring. What I'm asking is what is a good drop in the tripple clamps. My ball park is 14 - 20mm. Whats a good choice.
Scooter
scooter is offline
post #4 of 8 Old 03-06-2004, 11:56 PM
forks
I did mine at about 1/2" if I remember correctly. I think some have gone as much as 22 to 25mm.
rider1951 is offline
post #5 of 8 Old 03-07-2004, 12:49 PM Thread Starter
LOWERING
Rider 1951, so your running a 13mm drop. My bike was originally lowered when I bought it. (26mm drop in the front). Just put the preload caps on my 02. With 3 lines showing they are almost touching the handle bars. Your drop sounds about right. My dealer said to raise the forks up half the amount of the 26mm.
Scooter
scooter is offline
post #6 of 8 Old 03-07-2004, 05:51 PM
lowering forks
Scooter
I just went out and measured mine and they are at about 13-14mm. I don't have any clearance problems.
Dave
post #7 of 8 Old 03-07-2004, 09:36 PM Thread Starter
Forks
Thanks Dave
About 13-16mm sounds about right. I ask my dealership about doing this myself. I was wondering about the dirt that could be clamped under the tripple clamps, but they said just wipe the forks off. They also said do one fork at a time which seems strange to me because you would think this would damage things.
Brian
scooter is offline
post #8 of 8 Old 03-08-2004, 12:22 AM
lowering forks
No one at a time is the way to do it. Just be careful not to over tighten the bolts. Use a torque wrench as they don't take much. It is easier if you have a centerstand.
Help, all owners - front forks, could you try loose in lower front fork,please? bedeker DL650A - 2012-2016 3 07-11-2014 07:32 AM
Lowering the rear, but not the front Mastery Maintenance, Tech and Products. 9 04-26-2014 08:35 PM
Raised forks with fork brace and ABS bike BobA DL650 and DL650A - 2004 to 2011 25 07-20-2011 12:57 AM
Lowering forks in triple clamps Molasses DL650 and DL650A - 2004 to 2011 5 06-20-2011 08:03 AM
raising / lowering fork tubes DrDale General V-Strom Discussion 4 07-31-2009 02:49 PM
