Oxford Grip Glue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 33 Old 03-04-2018, 11:06 PM Thread Starter
dmfdmf's Avatar
Oxford Grip Glue
I recently installed some Oxford heated grips and they are working fine. However, the left grip has broken loose and is no longer glued to the handle bar. I am going to pull it sometime this week to reglue but I was wondering if there wasn't something better than the Superglue that comes with the kit. I put 3 stripes of glue down before installing but at the time I was thinking that maybe Superglue isn't the best choice. Can anyone recommend an alternative to Superglue that might be better for attaching the grip to the handle bar? Thanks.
Next Up: ?
dmfdmf is online now
post #2 of 33 Old 03-04-2018, 11:59 PM
scotty707's Avatar
I've heard 3M weatherstripping adhesive works well. It's waterproof and heat resistant.
2015 DL650
"I am learning ... that it is remarkably easy to do things, and much more frightening to contemplate them."
-Ted Simon
scotty707 is offline
post #3 of 33 Old 03-04-2018, 11:59 PM
I think I used hair spray.
06 V-Strom DL650
John V Strom, Jr. is offline
post #4 of 33 Old 03-05-2018, 12:53 AM
I used extra strength hairspray, and they were very tight going on......not budged in almost 3 years
post #5 of 33 Old 03-05-2018, 01:04 AM
Rolex's Avatar
If you dump the bike in a puddle and water gets under the grip with hairspray they will come loose.
iamsmiling likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 33 Old 03-05-2018, 07:23 AM
dbardell's Avatar
Same problem with my Oxford grips I just installed. Left side is loose and will need redone. I wondered about the super glue when I was putting them on....
dbardell is offline
post #7 of 33 Old 03-05-2018, 08:22 AM
Just installed a set of Oxfords and had the exact same problem; the super glue didn't hold on the left grip. Ended up removing, cleaning and reinstalling it using 3M weatherstripping adhesive.
I applied the adhesive to both the inside of the grip and the handlebar and allowed the adhesive to set up for about an hour, I think. Then I used rubbing alcohol on a hard cloth to wet the surface of the glue on the bar and quickly slid the grip into place. Let it dry overnight and you're good to go!
SCB123 is offline
post #8 of 33 Old 03-05-2018, 09:40 AM
I had the same issue and used Gorilla Glue. It doesn't move now, but I'm pretty sure I'll need an angle grinder if I ever have to change the grips.
Sent from my Pixel 2 using Tapatalk
Motor7 likes this.
919Nick is offline
post #9 of 33 Old 03-05-2018, 09:50 AM
I used a Locktite industrial adhesive, the kind that glues bricks. Only a dab of two so I could get it loose is necessary.
post #10 of 33 Old 03-05-2018, 12:03 PM
I stay out of water crossings.........I have yet to have any grip come loose from using hairspray, I ride in tons of rain too.
Spec likes this.
