Fog lights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By BorisB
post #1 of 10 Old 11-20-2017, 01:54 PM Thread Starter
Fog lights
Hello.
While missing riding my Vstrom because it's winter almost, I decided I should install some modifications on it. The first thing that came to mind are fog lights. And since I don't know much about them, I'm wondering which ones do you guys recommend. I really don't want to spend a lot of money for them, so I'm looking for a cheaper version that would "spice" up my bike a bit
Thanks for suggestions
matjazh is offline
post #2 of 10 Old 11-20-2017, 02:57 PM
Bowtie2bimmer's Avatar
Have a look at the ones from Adventuretech. Price is right and he is a forum member
Suzuki Auxiliary LED Lighting - AdventureTech, LLC.
A set from him is on my list of wants. One day i'll make the leap
2005 DL1000 - Nadine
2015 Triumph 675 Street Triple R
2007 Honda "Fiddy"
Bowtie2bimmer is offline
post #3 of 10 Old 11-21-2017, 02:21 AM
BorisB's Avatar
Check out Super Bright LEDS:
https://www.superbrightleds.com
They have a good sized selection with installation kits.
Cheers!
Clayyalc likes this.
BorisB is offline
post #4 of 10 Old 11-21-2017, 09:42 AM
Motor7's Avatar
Not much money?:
I put these on 15K ago on the '15...hung them on the turn signal stalks:
https://www.amazon.com/LYLLA-Motorcy...Y7J4CPX42XPBNJ
These on my '07 mounted to the highway bar for 30K miles:
https://www.amazon.com/Motorcycle-Dr...Y7J4CPX42XPBNJ
I prefer the turn signal stalk, it's rubber mounted, so less vibration to the lights. The brackets on the highway bar kept getting loose, so I JB welded them...no problem since then.
Yes I am a cheap lighting whore
'15 DL650XT
Motor7 is offline
post #5 of 10 Old 11-21-2017, 01:15 PM Thread Starter
Thanks for the suggestions. These LYLLA ones look pretty common, I see them everywhere And the price is pretty low, so I might try them out. I'm intend to mount them to the left and right crash bars. I suspect it shouldn't be a problem? Also it looks like they have a pretty strong "spot" beam...isn't that a bit annoying to other drivers? Thanks.
matjazh is offline
post #6 of 10 Old 11-23-2017, 08:27 AM
Motor7's Avatar
Not if you keep them pointed down a bit. I hate seeing a bike of car with brights or aux lights up in my eyes even during the day so I do my best not to do that. The triangle effect works even if the lights are not on bright or pointed ^up.
'15 DL650XT
Motor7 is offline
post #7 of 10 Old 11-25-2017, 10:23 PM
Motor7 is on the right track. I got some like that and they even had a blue flashing ring on the perimeter.
I cut the wire to that. Too official looking for comfort.
They are very cheap and need to be protected from fall overs. A proper mounting position is hard to find. I've bent the crap out of both sides so far.
They do make you more obvious to oncoming traffic whether they like it or not.
post #8 of 10 Old 12-31-2017, 02:37 AM
Lightbar and LED lights
I have the newly introduced light bar by AdventureTech for my 13' V Storm 650...I believe it fits years 12'- 16'..
I have posted some pictures in the gallery as well... check out my recent post if you would like to hear about my experience with the light bar.. Long short of it I have had one similar to it for a long time...
hoopitup is offline
post #9 of 10 Old 12-31-2017, 06:00 AM
eagleeye's Avatar
I've got the same ones as in the second link from motor7, and they are great. Everyone comments on them being bright and seen.
http://redirect.viglink.com/?format=...Y7J4CPX42XPBNJ
I did buy the bracket from Rick at adventuretech.
2009 Suzuki DL650
2005 Yamaha RSTD
2002 Triumph Bonneville
1980 Yamaha XS650 chopper
The Best Bike is the Bike You Like
eagleeye is offline
post #10 of 10 Old 01-03-2018, 01:18 PM
Nice lights, but the cast aluminum part that attaches to the light needs to be cemented on. I used e-6000. Loctite on the Allen bolt isn't enough. (Ask me how I know)
mikesova is offline
