DL1000 belly pan on DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 03-25-2006, 04:41 PM
cadhopper
Will the belly pan from a DL1000 fit on a DL650? If so how well is it constructed and does it really protect the oil filter? I tried to do a search because I sure this has been asked before but I had no luck. Thanks
post #2 of 3 Old 03-26-2006, 03:13 AM
They don't fit. You can either use an SV650 one like I have, or get a specific DL650 one. More to chose from if you go the SV route. I used a Powerbronze one, which needed a minor bit of cutting to fit around the gear lever (SV's are obviously a bit different in that area). It fitted up in under 15 minutes, and I think it looks great. Don't need to remove it for oil or filter changes either. I wouldn't say it actually offers a lot of protection for the filter, but it covers it up, as well as hiding the front pipe.
DL650 K5, Staintune pipe, topbox, Powerbronze bellypan, Givi E21's, Suzuki handguards
Barney is offline
post #3 of 3 Old 03-26-2006, 05:10 AM
cadhopper
Thanks for the info.
