Brighter Stock Directionals - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 05-01-2009, 09:30 PM Thread Starter
MILES2GO's Avatar
Red and Silver reflective tape for trailers etc.. from Walmart.
Cut silver to fit in directional light housing. Leave backing on.
I used red behind red faux light on my Suzuki top case.
Will try silver tomorrow.
08 DL650 Flat Black (sold)
Super Tenere in the garage by 8-13
MILES2GO is offline
post #2 of 18 Old 05-01-2009, 11:06 PM
rcacs's Avatar
Nice tip there Miles, thanks!
Cheers
rcacs is offline
post #3 of 18 Old 05-01-2009, 11:10 PM
donstrom6's Avatar
Thumbs up, Miles2go...I did the exact same thing a while ago with my signals, and also laid strips behind the red lens of my JCW topbox. Got the DOT tape at work.
Still haven't gotten around to taking pics, but it has to be an improvement!
And thanks for passing on a good tip! It's what makes this site one of the best!
DonStrom6 - PHL
Comfortably numb
DL1000K5 - Black
DL650K8 - Yellow (Sold)
donstrom6 is offline
post #4 of 18 Old 05-02-2009, 12:55 AM
silverstrom's Avatar
I'm just getting ready to switch to clear lenses and amber bulbs. I'll now be using this idea as well. Thanks!
The difference on the topcase is huge. I'll be doing that too!
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #5 of 18 Old 05-02-2009, 02:34 AM
K1W1's Avatar
Aluminium cooking foil behind the bulbs as a reflector also works and it's free generally (if you can steal some from the kitchen).
K1W1 is offline
post #6 of 18 Old 05-02-2009, 07:50 AM
Heavy's Avatar
Brighter signals?
https://stromtrooper.com/showpost.php...40&postcount=1
DL1000K6
Heavy is offline
post #7 of 18 Old 05-02-2009, 10:22 PM
jawmail's Avatar
Brighter is better IMO.
2007 DL1000 faster blue,bone stock, Givi 52L top case. center stand, heated grips, 2006 XR650L sold, 1997 Honda CR250R smoker sold, 1982 KZ1000ELR Eddie Lawson version sold (sad), 1976 Honda 550-4 sold.
jawmail is offline
post #8 of 18 Old 05-03-2009, 12:09 AM
FieroDude's Avatar
I wonder how well silver (or better yet, chrome) model paint would hold up if you painted the inside of the turn signal "cup". Biggest challenge would be leaving it time to dry thoroughly, I would think; I can't imagine that the signal assembly gets that terribly hot as long as the bulb is cycling and off and not staying on continuously for extended periods.
I seldom end up where I wanted to go, but almost always end up where I need to be. (Douglas Adams)
DL650 K5 - "Drachensfeuer"
DL650 K9 - "Drachensklaue" RIP 7-18-2009 with 5144 miles.
Silver Wheel Club #14
Official Mercedes killer, lol
FieroDude is offline
post #9 of 18 Old 05-08-2009, 12:57 AM
Originally Posted by Heavy View Post
For those that want to try this with the halogen bulbs. Be aware that this wont work with 1156 type bulbs. The 1156 bulb does not fit into the bulb socket of the turn signal. That is to say, it won't work on a 2009 V-Strom.
I attached pictures of the OEM bulb and the 1156 bulb, as you can see the little pins are not on the center line of the OEM bulb whereas they are on the center line for the 1156 bulb. I have seen the OEM bulbs for $5 - $6 online, pretty pricey if you ask me.
What I'll try to do is remove one pin on the 1156 bulb and see if I can somehow add a little pin in the right place to make it work.
Arne is offline
post #10 of 18 Old 05-08-2009, 01:18 AM
Just use a BAU15s bulb instead of an 1156 to fit the socket. It's only the late models with clear turn signal lenses that use that style.
