Performance and ride improvements - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 25Likes
post #1 of 25 Old 10-01-2017, 04:08 AM Thread Starter
With a budget of ~$1000 to $1500, what performance and ride quality improvements would give me the most for the money on a 2004 V-storm 1000?
ECU, exhaust, air filter, fork springs??
happystormrider is offline
post #2 of 25 Old 10-01-2017, 05:48 AM
Rolex's Avatar
We are all different but for me it was the seat, loved the seat on my Wee hated the V2 seat.
Next would be my Givi Airflow screen and I never thought I would say that until I tried one, they do work & work well.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 25 Old 10-01-2017, 06:48 AM
Do you have good riding gear? That can eat your money up pretty quickly.
Do you have issues with wind buffeting? Windshield and mirrors.
I would probably go into the suspension next, forks and shock.
Exhaust and air filter would be quite a way down the list. You will spend good money for not much difference in performance.
williecoyote is offline
post #4 of 25 Old 10-01-2017, 09:22 AM
In addition to what Willie wrote, fueling can be a problem on Vees. Careful attention to TPS settings and throttle body synching can help but some individual bikes really need something like a Power Commander to richen the lower rpm range a bit. If you do long distance touring, a seat change may be something to consider.
Changing the exhaust and air filter will probably make the lean fueling issue even worse.
post #5 of 25 Old 10-02-2017, 05:40 AM Thread Starter
Thanks for the feedback.
I'm thinking of installing the Power Commander and have the bike dyno-tuned. Is this worth it with stock exhaust? I've done it in the past on a Z750 and it made a HUGE difference: so much more throttle response and flatter torque curve.
post #6 of 25 Old 10-02-2017, 08:46 AM
Having it dyno tuned is probably an unnecessary expense but plenty of riders are happier using a Power Commander. There are a number of posts here which involve working PC fuel maps.
DesertBike likes this.
post #7 of 25 Old 10-02-2017, 12:14 PM
Brakes and suspension, really good gear.......that is money well spent and the most bang for the buck. Get a sport bike as a second scoot if you want real world performance.......my 2 cents.
realshelby likes this.
post #8 of 25 Old 10-02-2017, 01:54 PM
WildDoktor's Avatar
If you just bought an 04 dl1000, forget about "performance and ride quality"; you're going to want to assess the condition of the "reliability" parts: rotor magnets, stator, regulator, clutch basket, chain/sprockets, cush rubbers, tires. Replacing all of those will cost you nearly $1000...and you most likely *will* replace all of them sooner than later. Performance or ride quality gains will mean squat when you're stranded.
A volt meter, a speedo-healer, and the rear-wheel spacer would be maybe next on the list.
Then riding gear. Then suspension.
And then, as BigB says, a GSXR1000 for actual performance. :-) (And of course all the reliability parts for that bike. And gear. And suspension. And motor work. And...and...)
2004 V-Strom 1000 (currently broken - parts received - repairs in progress - snag hit - repairs on pause)
Two Brothers with P1 tips, PCIII USB, SuperBrace Fork Brace, K&N filters, ROX bar risers, Kappa top and side cases, MadStad, Givi tall windshield, Givi engine guards, Sargent Seat, 12 volt air compressor, 530 Conversion, 17/44, SpeedoDRD
WildDoktor is offline
post #9 of 25 Old 10-02-2017, 01:56 PM
B-Mac's Avatar
Must Have!!
PCIII ubs:Dynojet Power Commander Products
Two Brothers Slip on's Look for used
K/N filter
Race Tec Springs Front & Rear: Race Tech Suspension
or Wilbers Shock or EPM Shock/springs, see Klaus: High Performance Motorcycle Suspension Sales and Service from EPM Performance Imports
Brian
VSRI#505
B-Mac is offline
post #10 of 25 Old 10-02-2017, 11:31 PM
Considering most folks aren't out riding the capabilities of any 1000cc motor out there I would start with making sure it's all in top working order then look into comfort items. Like Willie said: gear, suspension, windscreen, grips, seat,etc. If you want performance and noise that a PC and exhaust can give you, we'll you bought the wrong bike. I'd recommend a GSXR750 myself
2 cents given. Good luck
jccity6 is offline
