48T rear sprocket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Cryoman
post #1 of 2 Old 08-23-2017, 06:42 PM Thread Starter
Moderating in moderation
Vindex1963's Avatar
48T rear sprocket
I removed the OEM 47t and replace it with a 48t . I didn't want to replace the front because it would give an increase in RPM that I didn't want. The 48t is a 2.13% increase in RPM and while not a lot I can tell rolling on the throttle out of a curve and accleration in 2-5th gear. I'm a pretty big guy at 6'3" and 245lbs and pulling mountain grades and general acceleration this seems like the answer without adding the 7.15% a front sproket would add.
At 65 mph indicated in 5th gear a 48t (+1) rear adds 115 rpm. 2.13%
At 65 mph indicated in 5th gear a 14t (-1) front adds 388 rpm. 7.15%
My gas mileage seems unaffected I've burned 2 tanks and both came in at 57 mpg with the OEM 47t is was a pretty constant upper 50's per gallon.
2015 Suzuki V-Strom DL650 bought new 4/26/17
2015 Victory Cross Country bought new 7/11/15 (dyno tuned 118hp 116tq)
If it's not broken, make it better
My take on oil: Name brand, wet clutch compatible.....BAM good to go.
Vindex1963 is offline
post #2 of 2 Old 08-24-2017, 10:39 AM
Thank you for posting your results. I'm planning the same when the time comes.
Vindex1963 likes this.
Cryoman is offline
