Power Adapter outlet - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 31 Old 03-16-2006, 10:07 PM Thread Starter
Send a message via Yahoo to SmkyMtnVStrom
Hi All,
Quick question. I want to be able to charge my cell phone or plug my GPS in to a cigarette lighter. Is there a mod for the strom to add one? Thanks
'05 Blue V-Strom 650
GO VOLS!!!
SmkyMtnVStrom is offline
post #2 of 31 Old 03-16-2006, 10:10 PM
Re: Power Adapter outlet
Originally Posted by SmkyMtnVStrom
Hi All,
Check this link out http://www.powerletproducts.com/prod...uki_vstrom.php
pilgrim is offline
post #3 of 31 Old 03-17-2006, 12:32 AM
Night_Wolf's Avatar
I picked up a cig lighter socket at my local automotive store. Wired a fused line direct to my battery and mounted it in one of the rings that hold the cables in place on the handlebars 8) I use it to power my GPS and plan on adding another socket before the season starts 8)
Hi All,
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #4 of 31 Old 03-17-2006, 12:52 AM
If I remember correctly the ground wire should go directly to the battery ground post. This is done to avoid issues of metals and aluminum not working well together if you ground elsewhere on the bike. Can anyone clear this up. My remembery is at low tide.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 31 Old 03-17-2006, 01:06 AM
You have it okay. It's recommended not to use the frame for a ground.
post #6 of 31 Old 03-17-2006, 08:28 AM
BillJones270's Avatar
Yeah, it's pretty simple to do. You can get an outdoor cigarette lighter outlet at Wal-Mart, or an auto parts store for like $7 -- it's just a simple 2 wire hookup (hot / ground). You can get fancy and hook them up through a relay, so they're only on when the power is on, add some inline fusing, etc. All in all, it's easy to do, I put 2 on my bike...well 3 if you count the 1 powerlet outlet for my heated vest.
BillJones270 is offline
post #7 of 31 Old 03-17-2006, 01:55 PM
VMan
Here's a nice one from Adventure Motostuff:
http://www.amotostuff.com/Merchant2/...650_electrical
Same one from California Sport Touring:
http://www.casporttouring.com/store/...e=Suzuki_DL650
Once installed, they look factory.
post #8 of 31 Old 03-18-2006, 09:35 AM Thread Starter
Thanks for all the info. 8)
GO VOLS!!!
post #9 of 31 Old 03-19-2006, 11:47 AM
Great information, I will definetly be adding one or more of those for cell phone and or GPS.
MIstrom is offline
post #10 of 31 Old 03-21-2006, 02:00 PM
I have the Powerlet setup, but any of the other options are great too. I didn't want to drill into the plastic panel so I bought a bracket to use that the Powerlet plug attaches too. I attached the bracket inside the fairing and use a two outlet adapter coming off that for my phone, GPS, etc. It also keeps it out of the weather and out of sight for the most part.
stlrmike is offline
