Anyone 5'7" reply, re: seat height please. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
  • 2 Post By Macdoc
  • 1 Post By realshelby
  • 2 Post By flyingjib
post #1 of 7 Old 08-08-2017, 08:17 PM Thread Starter
Hi,
My apologies for another seat height post. I haven't been on here for a very long time, and am looking at a used 2005 Vstrom 650 at the dealership. Very good shape with low miles.
Can be seen on Atlantic Motoplex web site Atlanticmotoplex dot ca. I cannot include the link as my post count here is less than 10.
I had a 2004 Vstrom 650 that I put 30,000 miles on, but sold it 4 years ago.
I'm 5'7" and can flat foot (both feet) on the bike at the dealership. It's been lowered, including modifying the side stand and the centre stand.
Does anyone think it's been lowered too much. I remember my stock Vstrom 650 being much higher, but don't have access to another one to compare to.
The thing is, after coming back from a work place injury (pelvis and lower back) it's a problem swinging my right leg over the saddle on stock height. I'm ok with the weight of the bike, just don't have the flexibility that I used to have. So I don't want the high stock seat height of the Vstrom (or the Versys either).
This lowered Vstrom at the dealership would be perfect. But I'm left thinking it my be lowered too much.
I didn't have time to test ride it yet to check for bottoming on rough paved roads, and will look at the rear fender to check for tire rub.
Also, I only ride on pave, never fire roads etc. And am willing to pack very light if needed for any trip.
Any advice would be greatly appreciated. I want to buy a bike this week, as I am beyond fed up of not riding.
If this lowered Vstrom is not a good idea (i.e. not safe) then I will go look at a used 2013 Honda CB500X as a viable (to me) alternative.
And yes I know the front of the front fender has been painted silver.
Thanks
Jim
jim-landry is offline
post #2 of 7 Old 08-08-2017, 08:49 PM
locoblanco's Avatar
Lowering the suspension could adversely affect handling. Suzuki has options for both higher and lower seats, this might be a better way to go.
locoblanco is offline
post #3 of 7 Old 08-09-2017, 01:03 AM
Macdoc's Avatar
Nothing wrong with lowering if done right - get someone that knows suspension to check it. Mine's down 1.25", lower seat, ( Terry Adcox ) taller boot heels ....handles fine.
Please...if you don't have personal knowledge of the factors involved don't make "could" comments. Doesn't help OP at all and raises unneeded concern.
The lowering needs to be done correctly by someone knowledgeable about suspension.
madstrom and chirosyd like this.
Canada 2018 CB500x >2009 CBF1000 sold • 10 Wee ABS sold • 09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR650 • 93 ST1100 sold •
Macdoc is offline
post #4 of 7 Old 08-16-2017, 07:30 PM Thread Starter
Thanks for the info. Reinforces what I already knew (or thought). I've been shopping for an lower seat height alternative, but nothing compares to the Vstrom as far as I'm concerned. The suspension was lowered at a dealership, so I am presuming it was done right.
post #5 of 7 Old 08-16-2017, 08:48 PM
Macdoc's Avatar
You can ( and I do ) get an inch on your boots and an inch with a low seat.
What is your inseam? ....height not as important as inseam.
Pretty bike
can't recall a silver.
If you can flat foot all ready you might be able to bring it upp an inch.
Macdoc is offline
post #6 of 7 Old 08-17-2017, 08:25 AM
The stock DL 650 seats of that generation are among the "lowest" you will find.
Sounds like a lot of work went into lowering this bike. Hopefully that means it was done properly.
Lowering does NOT automatically mean suspension bottoming. My ONLY concern would be the front or rear tire bottoming at full compression and hitting a part of the bike. If done correctly, that shouldn't happen. If it bottoms out on rough ground, simply buy heavier rate springs for front and rear. We used to think 4-5 inches of travel was just fine anyway!
madstrom likes this.
realshelby is offline
post #7 of 7 Old 12-12-2017, 10:13 AM
flyingjib's Avatar
Not sure if this post is still relevant but I'll give it a go anyways. Jim, another trick is to shave the mount rubbers on the underside of the stock seat. If I recall I cut mine down by half the thickness. It gives a bit of extra room. By the way, I am 5'6" with a 30" inseam and ride a 2006 wee which has been lowered 1&1/8". I also lowered the front forks by 19mm and replaced the stock seat with a comfy Sargent seat. I can't flat foot at stops but can get the balls of my feet both down on level ground. I found no appreciable difference in the handling with the lowering but I don't ride hard or fast. The DL has been a fantastic bike overall.
Earl
madstrom and dwayneh like this.
2006 Red Wee Strom
1984 Honda VT500FT Ascot
flyingjib is offline
