Suspension upgrade - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By 2mstone
post #1 of 10 Old 07-17-2017, 11:54 AM Thread Starter
Xstream's Avatar
Suspension upgrade
I'm 250lbs on a 2014 vstrom 1000
I want to put stiffer from springs in the forks and a stiffer on the rear shock
I just finished the Idaho BDR and was bottoming out hard on occasion
The bikes stock with a 70lb fork spring im thinking a 90 or 100lb spring and really don't know for the rear shock
Any comments or brand suggestions
Xstream is offline
post #2 of 10 Old 07-19-2017, 09:03 PM
Motor7's Avatar
Send you forks and spring to Jaime Daugherty @ DMr:
DMr Performance Suspension
or
Sasquatch @ APS:
Adventure Power Sports, LLC
Both have good reps and will do a complete re-work for around $750. I have the DMr and it completely changed the bike for the better on and off pavement(220 lbs here necked)
'15 DL650XT
Motor7 is offline
post #3 of 10 Old 07-19-2017, 10:00 PM
B-Mac's Avatar
hyperpro
Talk to Klaus at EPM
High Performance Motorcycle Suspension Sales and Service from EPM Performance Imports
I had his Wilbers suspension on my 04 and Hyperpro on my 14
Check out the rebuild and warranty policy also
Brian
VSRI#505
B-Mac is offline
post #4 of 10 Old 07-19-2017, 10:25 PM
2mstone's Avatar
Originally Posted by Motor7 View Post
Sasquatch @ APS:
That's where I would go, if I recall correctly he is near Boise.
notacop likes this.
"Tombstone"
S-10
My Alaskan Adventure
http://2mbstonestravels.blogspot.com/2015/04/alaska-or-bust.html
2mstone is offline
post #5 of 10 Old 07-20-2017, 12:38 AM
Any local suspension shop can put in higher rate springs. I'd contact Rich at Sonic Springs for his recommendation for fork springs. Changing the spring in inverted forks takes special tooling and knowledge.
Did you have the sag set for your loaded riding weight? You want about 40 mm of sag...suspension travel from wheel-in-the-air to you on the bike in your riding gear. This is set by the preload adjusters. Because you were bottoming out, and you're 250#, I'd have the preload set to the max. If you still hit bottom, yes new springs are needed.
post #6 of 10 Old 07-20-2017, 01:25 AM Thread Starter
Xstream's Avatar
Awesome thanks for the reply
I sent them a message after checking out their web site to see how long the turn around time would be
We have a local shop working on a 21in front tire mod and also has a mod to increase ground clearance by 1in so if I could get the suspension dial the wife would never see me
Xstream is offline
post #7 of 10 Old 07-20-2017, 01:29 AM Thread Starter
Xstream's Avatar
Yep I'm set to max
It's a 14 but I just bought it new outta the shop 2 months ago and right I away I took off to a dirt road with my screw driver and looped the road playing with the rebound and preload
I seemed to be okay with out luggage but this trip we just did was rough and we put the bike to the test fully loaded
Xstream is offline
post #8 of 10 Old 07-20-2017, 01:31 AM Thread Starter
Xstream's Avatar
Bummer I just went thru Boise I would of stopped on my way home from riding the Idaho BDR
Xstream is offline
post #9 of 10 Old 07-20-2017, 07:27 AM
Motor7's Avatar
Do your research on the 21"...some were happy, others miserable. More travel with what you have is always good, but a really good skid plate just takes the hits and keeps on truckin. I have the Happy Trails skid plate which is heavy duty.
'15 DL650XT
Motor7 is offline
post #10 of 10 Old 07-20-2017, 10:17 AM
Sasquatch rebuilt mine in a couple days and helped me install it at a camp out the next day!
I'd call that good service. A bargain price too!
notacop is online now
