LED turn signals - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-06-2006, 02:06 AM Thread Starter
LED turn signals
Anybody know of Led turn signals on a stalk or flush mount that are plug in for an 05 dl1000?
ononewheel is offline
post #2 of 5 Old 03-06-2006, 04:13 AM
Hi there OnOneWheel. I am going to assume you want things brighter and reasonably straight forward. I ended up with this combo. 50 watt halogen bulbs in the front(aka extra bright back-up bulbs) and LED's out back. The rears are about the same brightness. I also plan on putting reflective tape in all 4 signal housings. This combo draws approx. same wattage so the flasher doesn't get all silly and quit or go up in smoke. Hope this helps.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 5 Old 03-06-2006, 07:03 AM
wingman's Avatar
Picked up a couple of amber LED lights that fit at my local PepBoys for about $4 each. The light is a little brighter then OEM but does have a narrower broadcast spectrum.
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
post #4 of 5 Old 03-06-2006, 01:25 PM
VMan
LED turn signals
I got LED turnsignal bulbs from superbrightleds.com. I bought the white 19 LED bulbs and they're plenty bright. I also got the 50 watt bulbs - they are super bright, but I won't install them. This past weekend I installed flush mount turnsignals I got from eBay. The wire to the turn signals is very light gauge - like telephone wire. I'm afraid of melting wires or frying electronics. The new flush mount signals will require a 9 LED bulb in amber.
post #5 of 5 Old 07-20-2006, 11:14 AM
More resources if you are looking to install LEDs
I am heading down the same path. Try these:
http://11109.rapidforum.com/topic=11...turn&startid=1
http://www.customdynamics.com/led_strobe.htm
http://www.shockracing.com/products/...s&t=Superlight
In short, if you install LEDs, you need to compensate for the reduction in load that LEDs have over traditional bulbs. One way is to add more draw with the remaining bulbs. Another is to add aload management module in line. There are several types of modules offerred, example:
Note that there is a difference between the early 650Ks and the K4 and beyond.
Good luck.
650 V-Strom k6
Bitburger is offline
