Home made "V" Radiator Guard For $2.58 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-22-2009, 04:35 PM Thread Starter
To be fair I had all the material in the garage except for the j-bolts, ($2.58).
Pic 1 - Materials used:
1 piece 1/32'' steel approximately 9X14".
2 j-bolts 1/4/20X4" (Cut to desired length) with nuts and washers.
2 pieces 1/4' I.D. fuel line, (Cut to desired length).
2 8" Ty-Raps.
1 rattle can Rustoleum Satin Black.
Pic 2 - Parts assembled as they go on bike.
Pics. 3 & 4 Factory holes in radiator bracket where j-bolts attach.
Pics. 5 View of right side of installation on bike. Note location of ty-raps at bottom of radiator.
Note: Weight is completely supported by the j-bolts with the fuel line covering.
The grid itself rests on the solid outside frame of the radiator and NOT on the fins. The ty-raps carry no weight and just keep the bottom of the grid tight to the frame. The hardware will get painted to blend in. Nice solid installation for a fraction of the "Store Bought" price.
Ragnagwar is offline
post #2 of 6 Old 03-22-2009, 07:39 PM
av8or's Avatar
Send a message via AIM to av8or Send a message via Yahoo to av8or
where'd you get that perforated steel plate?
[COLOR=Blue]'07 Suzuki DL1000 V-Strom[/COLOR]
av8or is offline
post #3 of 6 Old 03-23-2009, 07:02 AM Thread Starter
Perforated plate
av8or,
I have quite a few pieces in the garage. Salvage from a dismantlement project at work.
post #4 of 6 Old 03-23-2009, 07:46 AM
CanadianFZ6's Avatar
Originally Posted by Ragnagwar View Post
av8or,
You can just use chicken wire (quater inch or so)... Spray paint it black... Cut to fit the rad (wrapp around the sides slightly). I did this on my Bandit, using the side bolts that held the aluminum rad end caps on to also hold the chicken wire on... Looked pretty good and cost a few dollars as well...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #5 of 6 Old 03-23-2009, 09:35 PM
Evolving Curmudgeon
kick's Avatar
I have a piece of that stuff as well and have been planning on doing the same thing so this was good timing. I am wondering though, how did you seal the radiator after you drilled a hole thru it for that piece of dowl?
'07 WEE-HAAAA! Blue, loaded & sweet
I'll know where I'm supposed to be when I get there.
kick is offline
post #6 of 6 Old 03-24-2009, 07:19 AM Thread Starter
Dowel Fix!
Elmer's Professional Wood Glue!!!!
