Heel/toe shifter for DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 03-15-2009, 04:55 PM Thread Starter
Due to an injury on my achilles tendon on my left foot, I'm having increased pain when I upshift. This problem will not heal and may get worse; the only "fix" is surgery with AT LEAST 6 months of recovery time.
So I'm looking for solutions, preferably one that doesn't include buying another bike.
I've already searched for this (heel/toe shifter); it doesn't appear that any aftermarket company makes anything like this. In fact, I didn't think I'd have any success since our bikes don't have floorboards for this type of accessory.
I'm looking at air shifters. They may be a solution. But it seems like a heel/toe would be better and less expensive. Or will I need to look for a good welder/fabricator in Orlando?
Thanks for your help in advance.
VeeTX
VeeTX is offline
post #2 of 4 Old 03-15-2009, 05:17 PM
Warhammer's Avatar
I've never seen an off-the-shelf heel/toe shifter that would fit. However, something like this should be very easy for even a so-so welder to make for you. A homemade heel/toe shifter would sure be cheaper than an air shifter setup.
You might go check with a few (not dealership) motorcycle mechanics. Not only would they probably be able to weld one up for you, they would likely have a bunch of spare shifters that could be used as donor parts.
Good luck!
Warhammer is offline
post #3 of 4 Old 03-15-2009, 07:53 PM
Heavy's Avatar
Not cheap but I bet Dale could help you with the setup.
http://www.holeshot.com/old/shifters/shifter3.html
DL1000K6
Heavy is offline
post #4 of 4 Old 03-15-2009, 08:16 PM
Heavy's Avatar
Actually, I read a little further and there is a less expensive option from Holeshot.
http://www.holeshot.com/shifters/ps2.html
Again, not Strom specific but, with some work...
DL1000K6
Heavy is offline
