Move controls slightly inboard to accomodate longer Oxford grips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By binto100
post #1 of 6 Old 05-05-2017, 02:19 PM Thread Starter
Greetings Stromers -
I am installing Oxford Adventure grips, Barkbusters and a Kaoko throttle lock on my 2016 DL650. I pulled the left stock grip off last night and noticed it is about 1/4" shorter than the Oxford grip. I'm sh#t w/ an exacto knive and don't really want to trim the Oxford grip. It seems obviously okay, but is there any reason not to loosen the left switch assembly (and mirror if nesc) and move it slightly inboard to accommodate the longer grip? Same thing for the right side, moving the brake assembly slightly inboard? The switch and brake assembly halves are held together using a phillips head screw or bolt. Are they locktited?
Thank you. This is a great website.
Bruce
Rides2Work likes this.
2018 DL1000 XT
Addons in process
Previous rides: Bultaco 175, Yam DT1 250, Kaw KZ750, Suz 1100E, BMW K1200RS, Hon 1100XX (most favorite), Valkyrie 1500, Yam FJR1300, Suz DL650
binto100 is offline
post #2 of 6 Old 05-05-2017, 03:44 PM
kcap122's Avatar
You might also run into trouble because the handlebar control assemblies are kept in place by detent screws that thread into holes in the handlebars themselves.
You'd be able to get away with this if you re-drill the holes slightly inboard and then mounted the assemblies there... BUT as long as you're going to all that trouble, it might be worth it to upgrade your handlebars at the same time :-D
kcap122 is offline
post #3 of 6 Old 05-05-2017, 05:20 PM Thread Starter
Dang, I never considered that. Hmmmm, why can't things ever be easy! I could drill and tap the handlebar but maybe I'll just trim the grips even though I don't want to. Even better, I'll pull the assembly this weekend and take a look so I know what I'm talking about before I make a decision. Thank you for your feedback.
binto100 is offline
post #4 of 6 Old 05-05-2017, 05:23 PM
marcham's Avatar
Bruce
Trim the Oxford grip shorter. The installation manual tells you how much is safe to cut. You will have a hard time with the throttle grip if it's not cut shorter. Also one you take apart the throttle tube you will find that it has grooves in it. The grooves will have to be removed (I used a dremel, sandpaper and a sanding block will do as well) otherwise you'll feel them through the Oxford throttle grip.
2015 VSTROM 650 X ABS EXP
marcham is offline
post #5 of 6 Old 05-05-2017, 06:47 PM
kcap122's Avatar
Forgot to mention. I've got the oxfords and stock bars as well, and I opted to just trim the bars. It's pretty easy. A 5 minute fix.
kcap122 is offline
post #6 of 6 Old 05-05-2017, 10:01 PM
kcap122's Avatar
Sorry, meant trim the grips.
kcap122 is offline
