Bought a set of Tokico 4 pots.... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 15 Old 05-04-2017, 07:44 AM Thread Starter
Motor7's Avatar
...and am collecting bits and pieces to put them together. I have the same calipers on my '07, but they were installed by the p/o so I have a couple of questions:
-the flebay calipers($50 shipped) have one missing and one broken dust shield. Looking at the "open" design I can't see any real benefit to a dust shield. Leave them off, or hunt down another pair?
-The oem '15 brake lines are a smaller diameter than the ones attached to the used calipers('03 750 gsxr). I am assuming that unless I change the Master and all the lines to it(which I really don't want to do) I should just use my own existing brake lines?
-I am going to re-build the 4 pots and found a pretty good sticky:
How to: Overhaul Tokico six-pot callipers
it's for 6 pots, but the 4 pots will be almost identical.
Prices on the re-build kit are kinda nuts....anyone with a good source post it up!
I'm in no hurry, so I am going to take a bunch of photo's and try and put together our own 4 pot sticky(if it's worthy of course)
'15 DL650XT
Motor7 is offline
post #2 of 15 Old 05-04-2017, 08:14 AM
I went with the OEM kits for rebuilding the calipers. Mine were off a salvage bike that was over 10 years old and had sat around for a few years. I did reuse my brake lines and they work well enough.
If I had to do over I would buy a set of calipers from a salvage bike that were not too old. The cost of the rebuild kit is ridiculous. Just install the salvage units and you will be flushing them anyway when finishing up the install.
realshelby is offline
post #3 of 15 Old 05-04-2017, 08:25 AM Thread Starter
Motor7's Avatar
Yes a pack of O-rings for $40(PER SIDE) is hard to understand. I have considered hooking them up, bleeding them and running the pistons out/back in a few times to see if any are sticky. Don't fix it if it ain't broke?
'15 DL650XT
Motor7 is offline
post #4 of 15 Old 05-04-2017, 08:32 AM
Brojon's Avatar
If they've been sitting it might be a good idea to take them apart, hone the cylinders lightly then clean thoroughly.
But if the o-rings are good then you're done.
"The further a society drifts from truth, the more it will hate those who speak it."
George Orwell
2015 DL650
Brojon is offline
post #5 of 15 Old 05-04-2017, 08:36 AM Thread Starter
Motor7's Avatar
But the little voice goes...."hey man those things are 14 year old...just sayin"...........
Hmmm, a disassemble clean and inspect does not sound too bad.
'15 DL650XT
Motor7 is offline
post #6 of 15 Old 05-04-2017, 09:13 AM
If I took them apart, I would NOT put it back together without new sealing rings at least. Just sayin'.....it is your brakes remember!
post #7 of 15 Old 05-04-2017, 09:51 AM
""hey man those things are 14 year old"
Hola, my 04 Wee isn't exhibiting any brake problems and I ain't changed the Brake fluid yet.
Should an item sitting on the shelf be necessarily bad?
Oh, I've successfully taken a stuck set of Honda brakes apart, cleaned and honed and reassembled without new parts.
It can be done.
post #8 of 15 Old 05-04-2017, 10:04 AM
It can be done.
Yes, it can be done. I have honed my share of wheel cylinders on cars and truck and put stuff back in that came out. But it was when I didn't have any money for new parts or couldn't get to the store to get them. It was also on a car or truck where, well back then brakes were not all that good anyway and a failure usually meant you had 3 other brakes. Maybe two?
New parts sitting on a shelf is different from used parts sitting with fluid in them. My experience with putting used parts back in is that it is a temporary fix. I have had them leak a bit of course, but also get to where they don't return properly. Which is even worse on disc brakes.
Not saying not to do it. Just be honest with yourself when you inspect those sealing rings. These are likely rectangular shaped, not round 0-ring type seals. Meaning if the edge isn't in perfect condition they are not in good shape.
Brojon likes this.
post #9 of 15 Old 05-04-2017, 10:53 AM
Brojon's Avatar
It can be done.
Exactly - you can see a bad o-ring.
Bend it - if it breaks or cracks it's done for.
Flat spots - done for.
Round and flexible - GTG
Where they go bad is
1 - crap settling on the o-ring
2 - corrosion made pits.
3 - o-rings deformed or non-pliant
1 & 2 can be handled by so cleaning and honing - the orings can be damaged when the piston moves. But if the orings are still viable I'd say go for it given the cost.
3 - you need a kit but cleaning and honing is still advised.
George Orwell
2015 DL650
Brojon is offline
post #10 of 15 Old 05-04-2017, 03:35 PM Thread Starter
Motor7's Avatar
Oneida Suzuki has the SEAL SET, PISTON 59100-29830 kit for $23.50 ea.....This is the cheapest oem kit I can find....tempted.
So no opinion on the dust covers??? Will the front end burst into flames if I don't have them??? :flaming_devil:
Arggg, the little voice won...went to order the seal kits....$22 and change Shipping....WHAT THE...........??
sheesh
KevinP65 likes this.
'15 DL650XT
Motor7 is offline
