fork skins - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 03-12-2009, 12:45 PM Thread Starter
msi1259's Avatar
fork skins
Has anyone put fork skins on their DL? In particular the Moose Racing fork Skins ( http://www.mxsouth.com/moose/moose-r...fork-skins.htm ). Does the short version (5") fit? Did you use the 33-43mm or the 44-50mm?
(a search on fork skins showed no hits) TIA
DL1000K5
msi1259 is offline
post #2 of 20 Old 03-12-2009, 01:00 PM
Heavy's Avatar
I've had them on mine for a long time now.
They were a challenge to get them on and to stay but, once set correctly, they're fine. Probably been there around 40,000 kms now.
DL1000K6
Heavy is offline
post #3 of 20 Old 03-12-2009, 01:41 PM
janiceclanfield's Avatar
HEY! You can't write about that here!
You'll have to move this to SPANK!
Oh. FORK skins.
Sorry...
:crying:
janiceclanfield is offline
post #4 of 20 Old 03-12-2009, 02:00 PM
I run a similar set that I made on my dirt bike. They work fine but you need to make sure you clean out under them regularly.
DL1000K8
So what is it, am I a smart*** or a dumb***? Maybe I'm just an ***hole.
10guy is offline
post #5 of 20 Old 03-12-2009, 02:24 PM
Heavy's Avatar
I hope that's not the case. I haven't touched mine except when I changed fork springs at the beginning of last season.
Originally Posted by 10guy View Post
...you need to make sure you clean out under them regularly.
DL1000K6
Heavy is offline
post #6 of 20 Old 03-12-2009, 03:01 PM
I'd pull them down and check and see what it under there. My dirt bike sees a lot of mud, more in one ride than most stroms will in their life time. After all I do live in the great pacific northwet.
DL1000K8
10guy is offline
post #7 of 20 Old 03-12-2009, 03:40 PM
Xavier6162's Avatar
There must be something wrong with me. I keek seeing "For Skin".
I often lose control. I really I hate my life.
Xavier6162 is offline
post #8 of 20 Old 03-19-2009, 11:11 AM
Evolving Curmudgeon
kick's Avatar
Do fork boots or skins work with a fork brace? I don't think they would cuz the skins need to be clamped to the top of the bottom fork tube right where the brace mounts up.
'07 WEE-HAAAA! Blue, loaded & sweet
I'll know where I'm supposed to be when I get there.
kick is offline
post #9 of 20 Old 03-19-2009, 11:17 AM
I cut around the bottom accordion pleat at the wide point and the boot sits on top of the brace. The springiness of the boot keeps it in place. I wasn't crazy about the idea when I first read it, but it really looks and works fine.
post #10 of 20 Old 03-19-2009, 11:46 AM
Banned
I run the Rancho RS1952's ordered at Advance Auto Parts, which I believe Greywolf still runs.
XLonDL650 is offline
