Oxford heated grips questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By slipstream
post #1 of 4 Old 04-22-2017, 08:45 PM Thread Starter
So thanks to all the info on this forum, I installed my Oxford heated grips today.
I connected them to the oem heated grip connection using an Eastern Beaver connector.
My questions is, during my trial ride this afternoon, I found the throttle grip was warmer than the clutch side grip. Is this normal?
I should mention, I only tried them for a couple of minutes.
Thanks in advance for any info.
Jumper is offline
post #2 of 4 Old 04-22-2017, 09:21 PM
I've got an old set that has several connectors for input and left/right side. I checked the fit of them and tightened a couple and got my grips working well again.
The bike is an 04 so they've been in use for a while. Best warmers I've experienced so far.
post #3 of 4 Old 04-22-2017, 09:39 PM
slipstream's Avatar
yes its normal because the clutch side transfers cold form the bar better...some have added a light insulation tape and it made them more equal.
Allagash likes this.
BOYCOTT Photobucket!
slipstream is offline
post #4 of 4 Old 04-22-2017, 09:50 PM
fortp's Avatar
Yes, the metal handlebar drain more heat than the plastic throttle tube, but if I remember well, this is compensated by more wattage on the left side.
fortp is offline
