BlueSea 5025 Installation Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 02-28-2009, 09:34 PM Thread Starter
Hallo,
I'm planning to install a BlueSea 5025 for all my gadgets. I went through a lot of posts. And now i'm just trying to make sure i understand all of it.
1. I will install Symtec heated grips over stock grips and will use grip puppies.
Will use "hidden" connector with Eastern Beaver adapter. I'm assuming that connecting heated grips to the stock "hidden" connector will will turn off grips while ignition is off (bike not running). Right?
2. Next I will mount 5025. I will use red 10G wire from + Batt to the Relay.
- What kind of Relay i could use?
- Does Eastern Beaver has any options? Any of you is using - 30A Fuse Panel Relay Kit (no fuse panel)?
- Where did you guys get yours?
And Black 10G for negative. I will also need a inline fuses.
- Do i need one on both wires (Neg and Pos) from the battery to the relay? - Where can i get them and what kind (30Amp)?
I was thinking to use a Rear Brake Connector Relay Switching Adaptor by Eastern Beaver also.
3. i will mount 3x12V for a GPS and 2xfor a heated liners.
Thx guys.
PLRider is offline
post #2 of 18 Old 02-28-2009, 09:47 PM
Either the OEM heated grip connector or the rear brake light switch connector from Eastern Beaver can be used to supply ignition on power to the relay (blue wire in diagram). Any 30 or 40 amp automotive relay can be used. They are normally marketed for horn relays. E/B also carries relays. Only the hot(+) wire needs a 30A fuse. The two wires from the battery need to be 10 or at least 12ga.
post #3 of 18 Old 02-28-2009, 10:01 PM Thread Starter
I will use a OEM just for a heated grips. And the rear break switch for a relay.
Thanks a lot for a quick respond.
PLRider is offline
post #4 of 18 Old 02-28-2009, 10:51 PM
TravellingStrom's Avatar
Send a message via Skype™ to TravellingStrom
Not the brake switch, use the rear tail light wire, this is powered when the ignition is on and off when it is off, this is used to power the relay.
The rear brake wire is only powered when the ignition is on AND the brakes are applied.
Just a bit of confusion between connector and wires I think, but I am sure you knew what you were doing
Cheers
TS
www.TravellingStrom.com
TravellingStrom is offline
post #5 of 18 Old 02-28-2009, 10:57 PM
The E/B brake light switch involves the hot lead to the switch, not from it. It's a good ignition on hot wire source.
post #6 of 18 Old 02-28-2009, 11:00 PM
OK, sorry, I though there may be some confusion and it turns out it was all in my own mind
Cheers
TS
post #7 of 18 Old 04-01-2009, 12:41 PM
Send a message via MSN to bcboy
Hi there new k8 650 owner. Where is the relay pictured on the bike itself.
thanks in advance.
jc
Don't tell me the skies the limit when there are footprints on the moon.
bcboy is offline
post #8 of 18 Old 04-01-2009, 01:06 PM
thanks in advance.
jc
We are talking about a relay used to turn on an auxiliary fuse block. Both are add on parts. People installing them have put the relay in different places. Basically, anywhere it will physically fit could work.
post #9 of 18 Old 04-01-2009, 01:57 PM
i have the blueseas fuseblock.
Can i wire the fuse block directly to the battery?
thanx again
bcboy is offline
post #10 of 18 Old 04-01-2009, 02:29 PM
thanx again
Without a relay, anything connected to the fuse block will always be on and draining the battery, even when the ignition is off.
