Sw-Motech Skid Plate Install Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 02-26-2009, 04:29 AM Thread Starter
braincellgenocide's Avatar
I did a search but didn't find much information, anyway:
So i'm trying to install my SW-Motech Skidplate and it looks like for the rear bar that the back of the skidplate attaches to, that I have to remove the two bolts holding the side stand in.
My question is, will the side stand fall off when i remove the two bolts? I don't have a jack or center stand to prop the bike up off the side stand to try it.
I've attached a picture of the install instructions with the bolt's in question pointed out in red.
Thanks in advance!
braincellgenocide is offline
post #2 of 5 Old 02-26-2009, 10:08 AM
Yes, it will fall. Put the bike in 1st gear, lean it against a wall and that's it.
If not ask a friend to help you out and hold the bike for you.
creativerider is offline
post #3 of 5 Old 02-26-2009, 10:14 AM
om28's Avatar
It will also require some serious torque to loosen those 2 sidestand bolts, you'll need a long ratchet or wrench, I used a long breaker bar on the socket.
2009 Wee Strom ABS (current)
1987 Harley Low Rider Sport (current - with 205K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, 1'' up & back bar risers, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
post #4 of 5 Old 02-26-2009, 10:37 AM
The bolts have thread locker applied. Heating them will break the bond and allow easier removal. Cleaning and new thread locker before re-assembly is a good idea.
post #5 of 5 Old 02-26-2009, 01:25 PM
x2 If you have an air compressor then it might be easier to use an air impact on them.
10guy is offline
