blue sea fuse box - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 01-17-2009, 10:21 PM Thread Starter
Talking blue sea fuse box
I js got a new fuse box with pos and neg terminals. I'm looking for some input on what to use for a positive feed. I want to run the terminals to be on only with the iginition on.
Thanks for the info, Drew
drew is offline
post #2 of 5 Old 01-17-2009, 10:30 PM
LordSmoke's Avatar
Here's what I followed:
http://11109.rapidforum.com/topic=11...rch=blue%2Csea
and you can pick up a switched wire from the brown tail light (DL650) in the wiring bundle running down the left of the frame. I just used a quick tap I had from my admore lighting kit.
I got the relay from radio shack. It works by using the current from the tail light passing through to ground to switch on the main power coming from the battery and going out to the BS.
I run my heated grips and admore lighting on my Givi through it. Works great.
Also, as you study the thread note the mention of a product by Eastern Beaver that is, I think, a plug-in adaptor that gives you easy access to switched power without tapping lines. And, I took the advice there about using a 30amp blade fuse between the battery and the relay. I picked up an inwire fuse from Advance Auto for a few bucks.
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #3 of 5 Old 01-17-2009, 10:33 PM
SCraig's Avatar
https://www.stromtrooper.com/showthread.php?t=31477
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 5 Old 01-17-2009, 11:38 PM
Here's a wiring diagram.
post #5 of 5 Old 01-19-2009, 09:47 PM Thread Starter
Talking thanks
Once again thanks for the info
drew is offline
