Handle Bar Risers Help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-19-2016, 12:23 PM Thread Starter
thedrifter2010's Avatar
I have a 2010 650DLA which I believe was not sold in U.S.A. for some reason and when looking up parts they seem to go from 2009-2011. So would the 2010 be basically the same as the 2011?
If ordering which one of the two below would fit my 2010 650 DLA without cable or hose extensions
Tusk Handlebar Risers 7/8" Bars, Fits: 2011 SUZUKI DR650SE 15mm Height
Tusk Handlebar Risers 7/8" Bars, Fits: 2011 SUZUKI DR650SE 30mm height
Many thanks for the help
Tim "the drifter"
thedrifter2010 is offline
post #2 of 3 Old 09-20-2016, 09:38 AM
Rick505's Avatar
I have a 2011 DL650A and initially used, I think, the 30mm adjuster. I can't imagine Suzuki making a change for one year and then reverting back the following year for a part as simple as a handlebar clamp. I did have a similar issue when I initially bought my 2011 new and most of the online parts places only had through the 2009 year listed. Ultimately I changed out the Tusk part as I wanted more pull back but they worked fine as intended.
Rick
Rick505 is offline
post #3 of 3 Old 09-20-2016, 09:53 AM Thread Starter
What did you change to from the Tusk part to ?
Thanks
Tim "the drifter"
