Great Deal: Hotgrips + HeatTroller = $110 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 40 Old 01-22-2006, 09:37 PM Thread Starter
This place sells HotGrips for $90 (list = $110), and is running a special right now where you can add a HeatTroller for only $20 (list $60). http://lockitt.com/AccessoriesGrips3.htm#hotgripsother
This is the best price you will find anywhere. Just ordered them up for my Wee-Strom.
I have no connection to Lockitt - just thought I would let others know about this great deal.
marathonman
marathonman is offline
post #2 of 40 Old 01-22-2006, 11:39 PM
STROMETTE's Avatar
Location: ON THE ROAD... (frequent stops in AZ-85338, TN-37205, CA-96150)
Well, Stromette might have to take a look at this deal a little closer after yesterday's 600mi jaunt in temps that ranged from 22 to just above freezing. Anyone know if a mechanical moron can install these things??
[B]aka "AGirl" - 2[/B][B]005 DL1000[/B]... [URL="https://www.stromtrooper.com/forums/showthread.php?t=5409&highlight=farkles+stromette"]MY STROM[/URL][COLOR=deepskyblue][FONT=Arial Narrow][COLOR=black][FONT=Arial] ...56,318 miles in 1yr of ownership[/FONT] :mrgreen: (2006 total miles on 2 wheels = 65,411) 8) [/COLOR][/FONT][/COLOR]
[FONT=Book Antiqua]* [I][FONT=Franklin Gothic Medium]Helmet laws interfere with Natural Selection[/FONT][/I]...[/FONT][B][FONT=Arial Black][COLOR=red]ATGATT![/COLOR][/FONT][/B]
[B][SIZE=4][COLOR=orange][I]:arrow: Join my journey...[/I][/COLOR][/SIZE][/B][URL="http://www.seizethejourney.com"]CLICK HERE[/URL]
STROMETTE is offline
post #3 of 40 Old 01-23-2006, 10:52 AM
MATTMAN's Avatar
Re: Great Deal: Hotgrips + HeatTroller = $110
marathonman
What size fits the Strom?
I need a set of these; I have found hand guards are not enough. Several cases of frostbite years ago has taken its toll on my fingers cold weather ability.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #4 of 40 Old 01-23-2006, 11:47 AM Thread Starter
#475-875 fit the Strom. Be sure and get the "open-end" grips if you intend to use the bar-end weights.
marathonman
post #5 of 40 Old 01-23-2006, 12:13 PM Thread Starter
I was concerned about the difficulty of installation as well. After researching this, I don't think it's too hard. Here are installation instructions and a wiring diagram from the HeatTroller website: http://warmnsafe.com/heattroller_han...m_hotgrips.php
Look at the bottom wiring diagram. If you connect to the OEM Heated Grips plug located behing the radiator, you can ignore the Relay and Fuse (because that power source is already switched and fused - electrical gurus feel free to chime in if I'm wrong on that one) . Connect to the OEM plug using a Horn Lead (OEM part #36852-06G00), available here for $15 delivered: http://www.ronayers.com/browseparts.cfm
If you wire it this way, you have:
RED Wire - to the OEM Heated Grips plug using the Horn Lead
BLACK Wire (ground) - to the (-) terminal on the battery
WHITE Wire - to Grips
BLUE Wire - from Grips back to HeatTroller
Not too hard. One other thing to consider is that you should solder any electrical connections, but again, that is something someone with (below?) average mechanical ability can do. Finally, here are the installation instructions from the HotGrips website: http://hotgrips.com/moto-inst.html
Any of you resident electrical gurus feel free to chime in here - especially if I'm wrong on any of this. I won't be offended.
marathonman
post #6 of 40 Old 01-23-2006, 10:50 PM
GGRJR's Avatar
Not a bad price, but I just ordered teh Suzuki factory grips from Oneida Suzuki
http://oneidasuzuki.com/store/customer/home.php?cat=519
for 120.00
Glen
2005 1K Blue
1993 VFR750F Pearl White
96 RC45 sold and replaced with a G35 Sedan
[FONT=Fixedsys][SIZE=3][COLOR=red]When arguing with a fool, make sure they are not doing the same.[/COLOR][/SIZE][/FONT]
GGRJR is offline
post #7 of 40 Old 01-24-2006, 09:52 AM Thread Starter
Originally Posted by GGRJR
Not a bad price, but I just ordered teh Suzuki factory grips from Oneida Suzuki for 120.00
I thought about getting the Suzuki grips, but they have received pretty poor reviews. For example: http://11109.rapidforum.com/topic=11...&search=suzuki
and
The HotGrips have received very good reviews from people who have them: http://www.motorcyclegearreview.com/...php?prodID=662
The problem with the Suzuki grips seems to be uneven heat distribution. For me, the HotGrips + HeatTroller seemed the best solution.
marathonman
post #8 of 40 Old 01-24-2006, 07:53 PM
echo's Avatar
I strongly suggest NOT getting a heat troller to use with your grips. You will use them on max 95% of the time anyway. If they do get too hot you can switch to low for a while. Why do you think theyre on sale?
echo is offline
post #9 of 40 Old 01-24-2006, 08:43 PM Thread Starter
Too late, Echo. My new HeatTroller was delivered today.
I think you're in the minority on this one. You are the only person I've ever seen argue that heated grips are better with a Hi-Lo switch than a HeatTroller. On the other hand, I've seen a lot of folks rave about the HeatTroller product.
I'm not sure why it's on sale, but I'm glad it is. It saved me $60.
marathonman
post #10 of 40 Old 01-24-2006, 09:27 PM
echo's Avatar
Well, see if you dont use it all the way turned up most of the time. If you actually use it on an intermediate setting I guess you got your moneys worth!
echo is offline
