Shift lever repair - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 12-22-2008, 11:10 AM Thread Starter
Dorzok's Avatar
Shift lever repair
First and most important!! Drop the bike on the left side at somewhere around 10mph while showing off in the front yard doing wheelies for the neighbor kids so that it will slide a good 10 feet.
Second, drag your sorry butt out from under the POS that just fell on you and limp and hop around cursing the machine to Hell.
Third, pick the stupid thing up,
Fourth, JB Weld the the peg back on.
Fifth, break the thing off on the way home from work while showing off to the hot blonde in the Corvette next to you.
Sixth, fix it right.
Harley parts. I cheaped out ($10). they make a really nice black knerled one but they only had in a kit with matching brake. woulda had to order just the shifter, was only like $5 more.
File the broken lever flat and smooth.
Drill jole and tap to match thread pitch on Harley part (SAE, not metric)
Re-install. Adjust height to accomodate for bigger size of Harley part because everything is overbuilt on those things that's why they're called pigs... i mean hogs.
Seventh, ride and stop showing off.
Dorzok is offline
post #2 of 3 Old 07-28-2009, 04:00 PM
kfb
I am attempting the same thing
It is interesting that Suzuki won't sell the small toe lever that always gets bent in a fall. Maybe it's because the whole assembly costs $80 and the small piece would only cost $10. Anyway I visited the Harley dealership and picked up the same piece for $10.40 plus tax. The parts guy was very friendly and told me that it was a 1/4" x 28 thread. I should be able to drill it out thread it and have it installed in about 1/2 hour. The difference is that I am going to do the tap with the shift lever in-situ. The Harley part is quite stout.
KFB
05 DL650 in Red.
kfb is offline
post #3 of 3 Old 07-31-2009, 03:42 PM
If you save the rubber cover, a bolt and washer from home despot can do the same for under a buck.
Strominid is offline
