Major Economy problems - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 11-17-2008, 06:30 AM Thread Starter
I have a 2002 Vstrom 25,000 miles with standard pipes, K&N Filter and custom map for power comander and loads of farkles. With this map I used to get 44 miles to gallon when running on super unleaded 99 ron. I recently took a trip to France and my chain snapped at 80 MPH. Luckily it freed itself and the only damage was broken front sprocket cover. However my fuel economy has got progressivly worse and now I am only getting26 miles to the gallon. I have tried alternate fuel maps but they don't make a difference. The bike is regularly serviced and looked after! Can anyone suggest a reason for this shocking fuel economy. With the price of fuel in The Uk I am getting about 130 miles to a tank with economical riding!
Please Help
Macca
maca_a08 is offline
post #2 of 14 Old 11-17-2008, 10:59 AM
Bisbonian's Avatar
How do your plugs look? If it's a rich-running issue they should be black and fluffy, I would also imagine the bike would be running fairly rough.
Have you checked your air filter? Even the K&N can become plugged, again I would imagine you'd be able to discern a loss of power if this were the case.
Have you checked your throttle body boots? Contrary to what you might think when one blow loose it will give you a rich condition.
I'm guessing there're no visible fuel leaks? Check the quick connects under the tank, while I wouldn't expect it perhaps there is a seal leaking.
That's all I've got.
Go hang a salami I'm a lasagna hog
Bisbonian is offline
post #3 of 14 Old 11-17-2008, 02:20 PM
V-Tom's Avatar
It sounds like you have. but to be sure have you gone through and checked all the basics? Air filter as previously mentioned, tire pressure, lubed the chain and checked tension, Plugs, throttle synced. Are brakes dragging?
My bike loses about 10 to 20% of its summer mileage as the temperature approaches freezing so a bit of a drop is normal.
Was the mileage drop gradual after the chain break (ie: got progressively worse over a number of tanks of fuel) or rather dramatic (next tank of fuel got way less mileage)? If dramatic, was anything else harmed by the chain break? Was the chain tensioned properly?
I don't have a 1000 but I have been told that Stroms like regular better than premium and get better mileage with it. I forget the corresponding RON and MON numbers but it sounds like the 99 ron is super. Did you always run the 99 ron? (North American Octane numbers are an average of RON and MON. Super is 91 plus here.)
..Tom
SMIDSY detailed report.
V-Tom is offline
post #4 of 14 Old 11-17-2008, 04:51 PM
That is an old wives tale Tom once properly adjusted to operate at low RPM's they will ping like crazy on low octane fuel especially at temps above 90 degrees F.
maca you may want to try running injector cleaner through a couple of tanks, sticking or sloppy injectors will cause a fuel mileage loss. If the filter has been allowed to dry out you may have excessive engine wear. Anything dragging enough to cause that kind of loss should show up as excessive heat somewhere. Perhaps the final drive gear shaft or bearing was damaged when the chain broke.
Mortaine is offline
post #5 of 14 Old 11-18-2008, 12:40 AM
V-Tom's Avatar
Good to know, Mortaine.. I haven't seen that happening on my 650.
..Tom
V-Tom is offline
post #6 of 14 Old 11-29-2008, 04:34 AM
What is involved in "adjusting to run at low RPMs" and why would you want to do that?
Anyway, on a stock bike it runs very happily on Regular.
Skippii is offline
post #7 of 14 Old 11-29-2008, 11:18 AM
If your TB synch, TPS and secondary throttle plates are all in adjustment....you should be able to run at lower RPM's all freakin day. I typically run 87 octane, but will use 89 or higher when the weather gets hot and muggy.
post #8 of 14 Old 11-29-2008, 05:50 PM
Banned
since the weather has cooled off here, i tried a tank full of 87 R+M/2 and noticed a decrease in MPG. >37 vs 40 or better.
Motorpsycho Jim is offline
post #9 of 14 Old 11-29-2008, 06:11 PM
Stromtrooper.com Sponsor
Jim Davis's Avatar
I'm sorry but it's hard to believe when you say "The bike is regularly serviced and looked after! "
No bike which is well serviced would ever have a chain snap. That's just being cheap, plus very likely the rest of the bike is NOT well looked after either.
I don't know why you're running HI octane, but perhaps that plus non-factory fuel mapping has done its damage. There is no telling what could be wrong, you're off the page in the manual.
Put the bike back to stock and you may be able to tell what is wrong.
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics: 2007 DL1000 with 16/43 gearing, Superbrace, Tokico 4 Pot fronts, BackoffXP, H4 Dual Relay Kit, PC-8 Fusepanel, 2 Powerlet Sockets, Suzuki Centerstand - 1988 Africa Twin 650, 1990 VFR 750.
Jim Davis is offline
post #10 of 14 Old 11-29-2008, 08:06 PM
V-Tom's Avatar
My experience, based on tracking my fuel mileage over 60,000 km (roughly 37000 miles) is that the mileage on my bike is about 20% worse near freezing vs. riding in summer weather. It's very hard to point to one tank of fuel and say a mileage change is due to the fuel if the temperature has also changed.
..Tom
V-Tom is offline
