center stand and hand grip guard questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 14 Old 05-31-2016, 08:07 PM Thread Starter
Hello,
I just purchased a 2012 650 w/ABS and 4k mikes which will be going in for the recall tomorrow.
There are a couple of upgrades I'll like to do right away and giving the number of options, I'm hoping someone can point me in the right direction to make it as painless as possible.
The pervious owner added some nice options (I think) but the bike doesn't have hand grips guards or a center stand. My hopes are to ride both hard surface and lite off rode. Recommendations on both are greatly appreciated.
Thanks
Leeland is offline
post #2 of 14 Old 05-31-2016, 08:38 PM
Can't remember what centrestand I fitted, but you most certainly should go with "Barkbuster" hand guards. I drop my Wee regularly ( yesterday the latest, approaching a "main" road from a very downhill side road....enormous cambers & a new layer of big gravel ...straight up & across and sideways into the ditch...bugger. ) & between them and Givi engine guards the bike isn't even scratched. The Barkbusters aren't the cheapest ones out there but they do the job. I've learned that picking the wee up gets much easier with practice !
yesbut is offline
post #3 of 14 Old 05-31-2016, 08:50 PM Thread Starter
Thanks for your reply. I've seem them demo'ed on You Tube. Given the tendency for these bike to fall over, I should probably go for the one with the full aluminum backbone.
Leeland is offline
post #4 of 14 Old 05-31-2016, 08:56 PM
Strongly agree !
yesbut is offline
post #5 of 14 Old 05-31-2016, 11:15 PM
shu
shu's Avatar
I just bought a new 2014 650 ABS a few weeks ago and last week I added handguards and a centerstand. My choices:
1.Barkbusters Storm Handguards. I've had Barkbusters on my DR650 for several years, through many, many drops and crashes. They help keep the bars from bending, protect the levers, and are tough. Installation is fairly simple, although there is some room for confusion. Do a search on this site for tips. In particular, read about how to take the OEM bars weights off.
2. SWMotech center stand. This stand works very well, literally stand up on the foot and the bike goes up and back- no pulling, no lifting needed. It is a very simple design and really is 'bolt-on'. A pleasure, actually, to install. I don't plan on using this bike off road, I kept the DR650 for that, so I don't have a skidplate. I'm not sure what skidplates would be compatible with which stands. If you're planning to get off-highway you'll be wanting crash bars, skidplate, etc and they will need to be compatible, obviously.
.................shu
reasonable likes this.
shu is offline
post #6 of 14 Old 06-01-2016, 08:46 PM Thread Starter
The Barkbusters you installed, did it have the full aluminum brace that connected to the handlebar grip and handlebar? I read on some models the master cylinder may prevent you from that style.
OEM bar weights? Not read anything about that. What does that accomplish?
Leeland is offline
post #7 of 14 Old 06-01-2016, 09:45 PM
shu
shu's Avatar
Yes, the Storm or VPS model both have the same full aluminum bar. I had no trouble fitting them on my bike. (I have the handlebars rotated about as far back as they will go, and the controls rotated slightly down.) You can rotate the master cylinder up out of your way while you work on the Barkbuster and then rotate it back in place when you're done.
The Barkbusters come with end weights of their own, so you remove the OEM bar weights when you install them. The trick to removing them is to loosen the screw a few turns and then tap the assembly in to loosen the plug. There's all kinds of stuff that can get loose inside the bar if you just remove the screw from the end and pull.
shu is offline
post #8 of 14 Old 06-01-2016, 11:11 PM
Macdoc's Avatar
Try Tusk as a less expensive but very strong alternative to BB.
I use Tusk on my 2010 and like the colours
https://www.rockymountainatvmc.com/p...lex-Handguards
Fiddly to mount but much cheaper.
and the best farkle of all....the Madstad windscreen mount.
Canada 2018 CB500x >2009 CBF1000 sold • 10 Wee ABS sold • 09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR650 • 93 ST1100 sold •
Macdoc is offline
post #9 of 14 Old 06-01-2016, 11:26 PM
kd70qc's Avatar
OEM Handguards and SW Motech Centerstand
I have the OEM Handguards. I'll have to admit I didn't think about how they would or wouldn't protect the bars in a crash. I was only thinking about the amount of coverage they would provide my hands from the elements and from brush. For that, I'm satisfied.
Regarding the SW Motech center stand: it works well, doesn't interfere with the side stand, and doesn't look likely to cause problems on hard leaning turns. It does takeaway about 1/2" to 3/4" ground clearance though. I find that I have to stand on it with all my weight and - depending on the surface - still help the bike a little by lifting on the grab bar on the left rear of the seat.
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #10 of 14 Old 06-01-2016, 11:28 PM
kd70qc's Avatar
Should have mentioned that my bike is a 2015 DL650XT.
Suzuki handguards
Fat, foamy grips
kd70qc is offline
