Installing Fuse Block - Wiring Recommendations - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-27-2016, 01:08 PM Thread Starter
johno_SLC's Avatar
I picked up a marine fuse block a few months ago and I'm ready to tackle installing it. I'd like it to be "switched" with the ignition, rather than hard-wired to the battery (to prevent parasitic drain on the battery when the bike's not running). I'm planning to run the positive cable through a relay to the battery, and close the circuit using a relay that's switched with the ignition.
Seems straightforward, and I'm sure a number of folks have done similar - which brings me to my question. Is there a sticky or a decent thread somewhere which shows how to do this? I'd love to have a guide. I've searched around the forum on various terms but haven't discovered anything yet.
Pointers or advice appreciated.
johno_SLC is offline
post #2 of 3 Old 05-27-2016, 01:17 PM
Here's a diagram. The blue wire for switched power can go to any of the sources in #3 at Basic V-Strom Wiring 101
Use a 30A fuse near the battery positive. There is also a thread at Aux Fuse Box Wiring - 101
post #3 of 3 Old 05-27-2016, 01:18 PM Thread Starter
johno_SLC's Avatar
Yah, never mind LOL. I always find the right information AFTER I post the question.
The definitive thread, I believe: https://www.stromtrooper.com/dl1000a-...installed.html
Tons of links to other threads and such.
