Installed Pelican 1430's, Not Good - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 10-31-2008, 04:13 PM Thread Starter
allthejerretts's Avatar
more holes than i needed, this pic was only first set of holes messed, up anyone have any idea what to fill the holes with
New SW-MOTECH Quick-Lock EVO Carrier, says to move rear blinkers I didn't do it, now i know why you need to move them
Anyway i am not happy with the results, I am thinking of making the left case a tool box, and buying a new case and starting over, one problem is that the left rack is different than the right rack, right case fits awesome, left side does not, i have to spend more time, i guess i am am going to unbolt it and move the rear blinkers,
Jerrett
N. Little Rock, AR
2007 DL650
SW side racks, Givi 360 x 2 side, Center stand, Givi 450 monlock topcase, Suzuki Handguards
allthejerretts is offline
post #2 of 8 Old 10-31-2008, 05:30 PM
Bisbonian's Avatar
I've used stainless button head allen bolts to fill in unwanted holes.
Go hang a salami I'm a lasagna hog
Bisbonian is offline
post #3 of 8 Old 10-31-2008, 05:38 PM
henerythe8th's Avatar
You installed the cases with the lids facing the wrong way...
If you put the hinges on the outside, then you'll avoid that issue.
There is information on the Pelican site regarding the correct type of glue that will work on the material in question.
Otherwise, since you're just plugging holes, so use silicone or JBWeld or epoxy.
Ever heard the old carpenter's rule?
NO!?!
Measure twice...
...cut once!
2011 MG Stelvio
henerythe8th is offline
post #4 of 8 Old 10-31-2008, 06:01 PM Thread Starter
NO!?!
Measure twice...
...cut once!
I used the side case on the right to mark my holes to drill, the right side case sticks out further than the the left due to the exhaust, I did not take that in to account, the first time i mounted on the left side, it did mount, but it was at a different angle and didn't match.
Jerrett
N. Little Rock, AR
2007 DL650
post #5 of 8 Old 10-31-2008, 06:05 PM Thread Starter
as for mounting the wrong way, I tried to match csr67 what he did. He had older racks, but they same brand, and his cases open up fine.
http://www.advrider.com/forums/showt...highlight=1430
I am thinking about getting some steal tubing to space out the case better
Jerrett
N. Little Rock, AR
2007 DL650
post #6 of 8 Old 10-31-2008, 06:13 PM Thread Starter
Rear shot, I have to work the next 3 days, so Tuesday I will try and fix the problems, as of now
2 Pelican 1430s, 1 Givi 350 Monolock top case
I need some more stickers
Jerrett
N. Little Rock, AR
2007 DL650
post #7 of 8 Old 10-31-2008, 06:18 PM
Living the Stereotype
Stromin'Nroman's Avatar
Sikaflex 150 contruction adhesive, black.
Comes in caulking tubes.
Find a bunch of other stuff that needs sealing when you open it.
Used it to fix a long leak in a plastic dirtbike fuel tank held up for two years until he sold it.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #8 of 8 Old 10-31-2008, 07:02 PM
E-Nigma's Avatar
Send a message via AIM to E-Nigma
I was thinking the same thing. Looks like one more should do the trick.
09 Orange DL650
"Your attitude is the only difference between an ordeal and an adventure"
E-Nigma is offline
