Need help installing crash bars - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 10-29-2008, 12:08 AM Thread Starter
Hey Guys,
I recently purchased and received some Fehling crash bars that I began to install the other day. When I tried to remove the 6mm hex bolt from the frame, the damn hex socket snapped in half and the bolt didn't even budge.
So today, I buy new hex sockets and try the whole process over again. This time, I'm paying close attention and I can feel the hex socket starting to fatigue and give. WTF? Does the factory use red loctite on these bolts?
So before I break another hex socket, do any of you guys have a better way of getting the damn hex bolt out without breaking the socket or the bolt itself?
Thanks for the help
la-motor
la-motor is offline
post #2 of 4 Old 10-30-2008, 03:04 AM
Jonnylotto's Avatar
Send a message via AIM to Jonnylotto
Use a better quality tool, make sure you're rotating counter-clockwise and if all else fails, try a moderate tap with a ball-peen hammer (poor man's impact wrench). You're trying to breakfree a cheap bolt that probably has a little corrosion action going on.
JonnyLotto
DL-650K5
"Honor does not need to defend itself nor does Valor need to fly a pennant to say 'I am brave'.
This is Pride mistaking itself for Virtue."
Jonnylotto is offline
post #3 of 4 Old 10-30-2008, 08:09 AM
There probably is thread locker involved. Heat is the cure for that. It also helps with corrosion but those bolts are stainless steel and that should not be a problem.
post #4 of 4 Old 10-30-2008, 09:50 PM Thread Starter
Thanks for your replies. I just found the post in the maintenence section regarding this exact problem. If I'd known that this was a relatively common problem, I would have done a search.
la-motor is offline
