Sonic Front and Hyperpro Rear Springs - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 13 Old 02-14-2019, 05:39 AM
jeeves's Avatar
Originally Posted by Pepe lopez View Post
can someone tell me what size allen wrench is used to take the set screw out on the preload collar? only post i can find says .5mm, that cant be right, and i want to have everything ready before taking out the shock, thanks, Pepe
1.5mm
Be very careful when removing it, because it's easy to round it, and then you will have a problem getting it out.
Use a good quality alen wrench and go slow. Squirt some penetrating oil before you try to get it out.
Sent from my Redmi 4 using Tapatalk
Don't ask...
jeeves is offline
post #12 of 13 Old 02-14-2019, 05:46 AM
jeeves's Avatar
It's was really easy to change the shock after removing the screw out of the preload collar
Don't ask...
jeeves is offline
post #13 of 13 Old 02-22-2019, 03:40 PM
Pepe lopez's Avatar
thanks, i got it out after some oil and heat, about the same setup too, with threaded rods and 2x4's, big difference with new springs up front and in the back, no more scraping the bash plate going home,
2016 wee strom -- when in doubt, give it gas
2009 KLR 50k
2005 KLR 25k stolen
1982 XJ1100 200k miles and going, only oil and plugs
1976 XS750 special
1966 international pickup, Harley retrieval vehicle
Pepe lopez is offline
