Big Bore kit for 650's - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 18Likes
post #1 of 24 Old 03-21-2016, 09:00 AM Thread Starter
Ex- moderator
This looks interesting.........
Zlock Racing
Why Motorcycles? Because Golf, Soccer, Football and Baseball only require One Ball
CollingsBob is offline
post #2 of 24 Old 03-21-2016, 10:51 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
I looked at this several years ago when I had a DL650. Kinda pricey and a lot of labor, but if your planning on rebuilding a 650 anyway it might make sense.
However, given the prices available on left over Vee2s, the math doesn't make sense if your not already planning on rebuilding an older 650.. As modified, my Vee2 is within 2 pounds of the DL650. And it was all bolt on and plug in modifications.
richlandrick is offline
post #3 of 24 Old 03-21-2016, 11:15 AM
DaveinNC's Avatar
From my HD days I can tell you once you start down that road you stick a knife in your reliability.
Ill wait for Suzy to unleash a 1200cc V Strom.
Big B likes this.
"Dave"
2017 VFR1200X Crosstourer (Chili)
2016 GL1800 Goldwing, sold good riddance.
2013 V Strom DL650 Adventure AKA Max, Fun, different, did I say fun? (traded)
2004 FLHTC Ole Red, all lower 48, several times (sold 180k miles did lower 48 four times)
1999 FXST Stage 4 Evo AKA Bitch Bike and holeshot king
1998 FXDWG Red Grey (sold)
1997 XL (Mom's bike)
1976 XLCH Iron Head (Leaker)
1978 ZIR TC (AKA Smoky) Rated "R" not for kids under 17 (Seized by father)
1976 CB 750 (AKA trouble)
1976 MT 250 Elsinore (My favorite, rode the country on a 2 stroke)
1974 CB 350-F4 (AKA Dog)
1974 Kawi 100E (AKA Sparky the mud bug)
1972 KV 75 kawi
1970 Rupp mini bike
DaveinNC is offline
post #4 of 24 Old 03-21-2016, 11:32 AM
The first weak spot on DL650 performance improvement is the connecting rod. Push the envelope very far and you'll have a paperweight instead of an engine.
Big B, CollingsBob and DaveinNC like this.
post #5 of 24 Old 08-04-2016, 10:41 PM
This would be interesting if you could build the engine to have only slightly more horsepower, but dramatically improve the low and mid range torque.
Highside71 is offline
post #6 of 24 Old 08-04-2016, 10:48 PM
RichDesmond's Avatar
Torque is a function of displacement and BMEP. You're not going to improve BMEP hardly at all, so that leaves displacement. A "dramatic" improvement implies a lot bigger increase than a big bore will give. If you want more torque, buy a 1000.
hellebauer likes this.
Rich Desmond
RichDesmond is offline
post #7 of 24 Old 08-04-2016, 11:04 PM
"Dramatic" was a poor choice of words, noticeable would be more like it.
Plus given the fact that the 650 can run on 87 octane, that shows that there's room to bump up the compression.
post #8 of 24 Old 08-05-2016, 03:26 PM
True, that will give you a bit. Probably not enough to feel.
Overall, the 650 motor is not a good candidate for significant HP or torque increases. The bottom end is just too fragile, and there's no fix for it. I've got a broken Falicon crank from one of my race SVs as a testament to that.
Big B and Spec like this.
Rich Desmond
post #9 of 24 Old 08-07-2016, 11:37 AM
Rave-Man's Avatar
The V-Strom can never be regarded as a racer so why mess with it? Suzuki do two sizes for both types of petrol heads, one 650 that will do more than most can handle and the 1000 that can do the same with a little less effort.
Not sure where the extra power or torque is required as both deliver and depending where your riding then gearing may be a cheaper option.
I could understand this mod on the SV "maybe", but not on the Strom. Just my two bits!
Big B, Spec and DaveinNC like this.
Rave-Man is offline
post #10 of 24 Old 08-09-2016, 09:18 AM
Curious that I see mention of cranks suffering damage when most folks call the Wee bullet proof.
Is this more of the nature of bikes used for racing and power seeking engine mods?
Mine sees higher RPM occasionally but most of the time 5-55K rpm is all I need.
