Rox Risers (2") Non-ABS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 10-06-2008, 06:57 PM Thread Starter
79SouthJim's Avatar
Hello,
I am trying to install some 2" Rox Risers on my Wee. Everything I have read here so far seems to indicate I should not have any trouble with the cables, since I do not have ABS, other than maybe some minor adjustment. I am feeling no wiggle room what so ever once I loosen the handlebar clamps.
Below is a photo of where I think there is a problem. It is with these coiled wire guides (for lack of a better term), but I see no way to easily free the cables from these guides.
Any input would be appreciated.
Thanks,
Jim
79SouthJim is offline
post #2 of 12 Old 10-07-2008, 12:26 AM
I got rox
Hi, you just unwind them. That's what I did anyway. You can hold the wire with a pair of needle nose pliers. It's kind of like push the wire over the hose and keep going. Good luck.
taildragger is offline
post #3 of 12 Old 10-07-2008, 10:27 AM Thread Starter
79SouthJim's Avatar
Most appreciated, Thanks! It makes sense and I started to do that and got this weird feeling I was going to break it. I will go at it again tonight without worrying about doing any damage.
Jim
post #4 of 12 Old 10-11-2008, 12:51 AM Thread Starter
79SouthJim's Avatar
Finally got it. Holy Cow. That was not as simple as I had hoped. Pull this, yank that, twist and test, tweak this, re-install that, watch the tank.
After a week of installing stuff (centerstand and rox risers), it's time to actually ride the thing! The farkling stops here.
post #5 of 12 Old 10-12-2008, 08:16 PM
Please post a picture
I am thinking of installing Rox Risers on my Wee. Please post a picture of your completed install. I am considering the Elite 2" Riser. Which one did you install?
Thanks,
Honda Convert is offline
post #6 of 12 Old 10-16-2008, 10:32 AM Thread Starter
79SouthJim's Avatar
Honda Convert,
I installed Rox Risers. No regrets. They make a big difference. Pix below as requested.
post #7 of 12 Old 12-09-2008, 11:41 PM Thread Starter
79SouthJim's Avatar
No replacing wires, but due to my lack of mechanical skills it took me a while to figure out how to get a little more slack out of the brake line. That's just a matter of rotating the bracket on the lower fork clamp. Also, I ended up cutting the coiled cable guides (for lack of a better term).
post #8 of 12 Old 12-10-2008, 07:37 AM
Heavy's Avatar
Originally Posted by 79SouthJim View Post
...After a week of installing stuff (centerstand and rox risers)...
A week for centrestand and risers? I've heard of taking your time and doing it right but...
DL1000K6
Heavy is offline
post #9 of 12 Old 12-10-2008, 11:34 AM
Ironheadziggy76's Avatar
I installed these risers on my 05 Wee and had to make a couple of adjustments while doing so. Everything was fine except at full lock, I had to move the brake line clamp down the line a little as others have noted. I also had to rotate the throttle cable housing a little or they would bind. The previous owner had installed grip heaters and had the housing pointing upward. I loosened the housing and rotated it back down slightly and all works fine now.
2017 White DL650, "Rachel"
Givi Air Flow windshield, Corbin seat, Happy Trail luggage, for now...
2005 Red DL650, "Annabelle"
SW-Motech crash bars and centerstand, Corbin seat, Symtech grip heaters, PIAA driving lights, Fenda Extenda, MP Cycle Designs windshield, Rox risers, mirror extenders, 16 tooth cs sprocket, Adventure Motostuff skid plate.
2002 HD Road King Classic
1976 HD Sportster
Last edited by Ironheadziggy76; 12-10-2008 at 11:36 AM. Reason: My spelling sucks.
Ironheadziggy76 is offline
post #10 of 12 Old 12-10-2008, 07:13 PM Thread Starter
79SouthJim's Avatar
I am a "step-by-step" instructions guy and I can tell you any instructions I got from SW-Motech (for the centerstand and skidplate) were not step by step. Way too much thinking involved for me. If I get frustrated it turns in to beer time (so I can gather my thoughts), that's were I think my projects start to fall apart.
