Potentially stupid light question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 02-13-2016, 06:51 PM Thread Starter
Ex- moderator
I take forever to settle on a farkle...I'm considering adding LED lights to increase daytime visibility and to augment the high beam for night time riding..So...can anyone tell me if there is any significant difference between these;
Denali D2 Dual Intensity LED Lighting Kit with Full Wiring Harness and M8 Mount - TwistedThrottle.ca
And these;
MondoMotos MM10 Bullet LED Auxiliary Light Kit (V3) | MondoMotos Motorcycle Lighting, LED Lighting and Accessories
They look to be of equal output.....
Why Motorcycles? Because Golf, Soccer, Football and Baseball only require One Ball
CollingsBob is offline
post #2 of 5 Old 02-13-2016, 07:57 PM
cpd419's Avatar
Best warranty for me. These new fangeled led's and Crees aren't as dependable as advertised in my experience.
2013 DL650
cpd419 is offline
post #3 of 5 Old 02-13-2016, 09:20 PM
Matt_Mc's Avatar
The Denali's are dual density meaning they have a high and low beam which from the specs is a 10* spot light or a 40* flood light. The second pair is a 25* light which is still along the lines of a flood light but not as wide but definitely not a spot light.
Up against the $80 lights I had on my KLR compared to the expensive Denali's on my Strom, I liked my cheaper KLR's lights better. That and if they went bad or I broke them they were 5 times cheaper to replace.
Matt_Mc is offline
post #4 of 5 Old 02-13-2016, 09:32 PM
Post heat matters
And these;
I see a couple differences which seem significant to me. The MondoMotos MM10 Bullet appears to have some kind of over-temperature protection whereas the Denali D2 description makes no mention of such. The write-up is not clear, but from it I infer that the MM10 has circuitry to reduce power so as to limit temperature rise. This seems like a good idea for the application, where the amount of airflow is highly variable and can go to zero. Then again, the D2 has a slightly better package for imparting waste heat into the airflow. On balance, I would prefer the protective circuitry, if that's what it is.
Trepidator is offline
post #5 of 5 Old 02-13-2016, 10:24 PM
jrnyer's Avatar
I didn't want to spend a fortune on auxiliary lights so I bought the MondoMotos. For the price they are an excellent buy, they are bright but not too bright for daytime lights. I have them mounted on the forks just above the front fender. Gives a good triangle of light.
Boycott SV Racing
jrnyer is offline
