Removing black hand guards- Then the posts!!!??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 11-16-2005, 02:29 PM Thread Starter
I have removed my black plastic hand guards form my 1000. Now I am left with two, tall, hexagonal posts which used to secure the screw in the hand guard. Has anyone removed these posts and replaced them with anything for looks? I'm afraid that since the posts also go through the hand levers, if I pull them my levers will go shooting across my garage!
wgm114 is offline
post #2 of 5 Old 11-17-2005, 12:11 AM
BBurton "BigB"
Only one way to find out!!!! :lol:
post #3 of 5 Old 12-23-2005, 10:27 AM
I wouldn't worry if I were you. I did the reverse operation on my 650. Had to emove the bolts that go through the levers. No problems whatsoever. But why do you want to remove them? Personally, I noticed a relief on buffeting after I intalled the hand guards...strange, but true!
spidrgr is offline
post #4 of 5 Old 12-30-2005, 10:40 PM
It's true! There is only one way to know for sure. Be wearing protective eyeware and then VERY slowly remove those bolts!
Just kidding. They are the pivot bolts, that's all. In this case they are unusually tall to hold up the hand guards. The pivot surface of these bolts should always be kept clean and well lubricated for good control of your motorbike. I can't tell you how many bikes I have borrowed or rented that badly needed this quick and simple service. Dirt gets in there and the grease slowly degrades so it's hard to notice anything is wrong.
I'd bet a quick trip to the dealer or other parts purveyor would get you some pivot bolts that would work perfectly without the post effect.
Cheers!
'06 DL-1000
'06 KLX 250S (more fun than people should be allowed to have)
'72 SL-350 K2 (bump start only)
'72 CL-350 (on injured reserve list at this time)
I guess it's better to bend a valve in Missoula than to lose your mind in Bozeman.
-Barb Egan
MWValley is offline
post #5 of 5 Old 01-03-2006, 01:34 PM
Hoppy
Re: Removing black hand guards- Then the posts!!!???
Would you like to sell your hand guards?
Hoppy
