1 spot, 1 flood, or? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By Wildbill1945
  • 1 Post By stone
  • 1 Post By crawfcj
post #1 of 8 Old 01-12-2016, 10:13 PM Thread Starter
Ex- moderator
Im considering the Adventuretech LED lights, they offer 2 spots, 2 floods or one of each. Whats the consensus on best choice & why?.. If I go for one of each I assume that the flood would go on the curb side of the bike..
I look forward to your opinions..
Why Motorcycles? Because Golf, Soccer, Football and Baseball only require One Ball
CollingsBob is offline
post #2 of 8 Old 01-12-2016, 10:33 PM
Spot
The LED is very bright and when mounted low, around front wheel hub height, the headlight/LED combo sends out an unusual triangle of light that may attract cagers' attention. The problem is beam dispersion. A flood might have a 10 degree angle and at 100 meters it is fully dispersed. A spot might have a 5 or even 3 degree angle so it will still be fairly concentrated at that distance but not at 200-300 meters. ADVMonster sells a 1 degree unit but its lumen out put is too high for street use and cannot be dimmed (but could be turned off). I have found the aux LED in 10 watt are noticeable visually within 50 meters but will not light up anything beyond that unless is it a reflective sign like a speed limit sign. It will not help much with deer. I have them for day time defensive purposes, not for night time lighting up the scene in front of me.
CollingsBob likes this.
Wildbill1945 is offline
post #3 of 8 Old 01-13-2016, 10:00 AM
Don't know about Adventuretech. I have been running cyclops motorsports LED's. Flood on the curb side, often with a yellow filter and 10 degree spot on the left slaved to tf he high beam. Have em chin mounted on a home made bracket . Fanastic setup, works great, no complaints from oncoming traffic when used intelligently. Nice to be able to use the trigger on the high beam to become conspicuous when needed.
Sent from my SM-G900V using Tapatalk
stone is offline
post #4 of 8 Old 01-13-2016, 10:41 AM
I installed Rigid Dually LEDs and went with a 10 degree spot on the left and the 20 degree flood on the right, fork mounted. I'm happy with that choice after testing it out on really dark and curvy rural roads. I would do it again the same way.
Charlie
2012 BMW R1200RT, 2013 Honda PCX150, 2014 Suzuki DL650A
Add-ons: SW Motech Center Stand, Parabellum 24" Windshield, Adventure Tech Over the Dash GPS Mount and Mirror Extenders, Blue Sea Dual USB Port, Shad 49L Topcase, Rigid Industries Dually Spot and Flood LEDs, Whelen 700 LED Brake/Tail Light, Kisan Headlight Modulator, Terry Adcox Double Bucket Custom Seat in all leather, and the following Eastern Beaver products: PC8, H4 Dual Headlight Relay, Brake/Tail/Signal Adapter, Rear Brake Light Switch Connector Relay Switching Adapter.
crawfcj is offline
post #5 of 8 Old 01-20-2016, 12:46 PM
Denali D4's. Best of both worlds.
Wallygator is offline
post #6 of 8 Old 02-21-2016, 11:39 AM
If you never rode at night, (or never plan to), like myself, would spots X2 be the correct choice? I am a big fan of riding with the high beam on all the time to be seen and I'm thinking of some crash bar mounted led's.
Thanks
2009 DL1K
2015 Street Glide Special
2011 Road King 106" SOLD
Dene09 is offline
post #7 of 8 Old 02-21-2016, 01:09 PM
Vstrom N Me's Avatar
This is what I run and they cost under $100.
https://www.stromtrooper.com/dl1000a-...ds-merged.html
Scroll down a bit
Vstrom N Me is offline
post #8 of 8 Old 02-21-2016, 01:28 PM
2x Cree U7 3000LM White Strobe Lamp Motorcycle LED Fog Spot Work Light HeadLight
I got from ebay, 1 week delivery, free.
Bright as could be. I need to point mo bettah but better than head lights.
