Autocom Help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 11-05-2005, 10:37 PM Thread Starter
Autocom Help
I'm admittedly not an electrical system guru. I have a new Autocom set, but I'm not really sure how or where to wire it in. I'm sure I saw an example on here a couple of years ago, but I can't for the life of me find it.
I would be forever grateful if someone please explain how they have their set wired in. If you have any pictures or links to pictures that would be even better.
Tony T.
'03 V-Strom
'03 Triumph Bonneville T100
'70 Triumph T100C
v1cut is offline
post #2 of 4 Old 11-06-2005, 07:59 PM
I'm in the same boat as you. I'm told you can use the tail light feed (or any switched wire to power the autocom. I'm not too keen on cutting into the loom so I'm going to use one of the taps in the bottom of this page till I get theswitched power block sorted.
http://www.2wheelinnovations.com/Dis...n%20Blocks.htm
Now, back to trying to fit the mic and earphones in the helmets.
Mike
DL1000K5 Black with extra black bits.
Fast Traveller is offline
post #3 of 4 Old 11-06-2005, 08:22 PM Thread Starter
I sorted it out myself. After studying the dizzying electrical system schematic I obtained online, I decided the brown wire coming out of the tail light wire bundle was the one I needed. I attatched the ground wire to the battery and spliced into the brown wire for my positive lead. And waddya know, it worked.
Can someone at least let me know if my bike is going to explode, implode or any other disaster as a result of my wiring job?
Thanks
Tony T.
'03 V-Strom
'70 Triumph T100C
v1cut is offline
post #4 of 4 Old 11-07-2005, 08:00 AM
No it might smoke a little then catch fire but you'll get off before that
regards camo
But you sound like you've got it :idea:
I go hard because I cam
Flage is offline
