DL1000K3, Power Commander III, Secondaries out, backfires... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 11-01-2005, 06:51 PM Thread Starter
I recently installed a Power Commander III USB in my DL1000K3. I am using the M311-001 map - 02-03 Model for Completely Stock Bike. This map checks out with the computer, both cylinders are mapped the same.
I wasn't completely satisfied, it seemed to lack the old punchy acceleration, so I yanked the secondary butterfly valves.
Wow! What a difference! Bike now pulls from 1500 to 9500. It is smooth the whole way up. It is just a smidge rough at 3000-4000, a really small smidge. At 4000-7000 it's like an electric engine, then gets a bet fiesty. Acceleration is far better than brisk. I'm happy.
Gas mileage went from 41mpg to 43mpg for same riding conditions. Not bad, better performance, better mileage, such a deal!
However, there is a "fly in the ointment". I occassionally get a small backfire, especially when the bike is hot (3 bars). This occurs at low rpms, when I start a slow acceleration. There seems to be a lull in the engine just before the backfire.
I'm running the idle about 1400 to keep it from stalling. I may be able to lower it. I set it before PCIII and removing the secondaries.
Any ideas on how to fix this backfiring?
ejy712 is offline
post #2 of 9 Old 11-01-2005, 08:32 PM
Sounds like a balancing of the throttle bodies is in order.
"Travel has no longer any charm for me. I have seen all the foreign countries I want to except heaven & hell & I have only a vague curiosity about one of those."
Twain
BradM is offline
post #3 of 9 Old 11-01-2005, 10:45 PM
Perhaps the low RPM fuel value is set too low (too lean) in the MAP?
I got my Wee-strom (first motorcyle, first motorcycle I've ever been on period) and scared the snot out of myself.
Corpsie is offline
post #4 of 9 Old 11-12-2005, 09:21 AM
I've got an '05 DL1000 set up similar to yours: stock air filter, stock pipes, and a PC USB III. I recently gave it a "secondary-ectomy", and I've got to agree. It ran great before, but removing the STPs takes the bike to a whole new level; it's magic.
As for your backfire issue, if all else is in order, you may want to try a different map. I have (what appears to be) a custom tuned version of map M311-501. I bought the bike used, and the PC was all ready installed. I recently pulled the map down from the bike to check out what version was installed. The file was named M311-501 but was different from the version off the Dynojet site.
If you want a copy of the map, let me know and I will e-mail you a copy. Again, I'm not sure who did the tuning, but I cannot imagine my bike running any better.
Rick
Semper-V is offline
post #5 of 9 Old 11-12-2005, 09:27 PM
JohnInNH
Where can I get a detailed HOW TO for a "secondary-ectomy" With pics etc..
I think I should do this after reading all the PROs
Any CONs?
Thanks from a new guy.
post #6 of 9 Old 11-12-2005, 11:04 PM
https://stromtrooper.com/forum/viewto...er=asc&start=0
Twain
BradM is offline
post #7 of 9 Old 11-13-2005, 10:55 AM
JohnInNH
When I look at the part drawings there are two sets of butterflys.
I would think the top would be the primarys and the lower the secondarys... I don't want to remove the wrong ones.
The write up makes it sound like they are the TOP most round plate/butterfly
Is this true?
Sounds like a MUST DO...
Any other MUST DOs for this bike.. (I have the teka re-map, center stand on the way, and a new WindStrom Manta)
BrianMA and I are taking a trip this coming week. He's got 3 days off and we want to see how far south we can go. LOL... Let's hope for warm and DRY weather!
post #8 of 9 Old 11-13-2005, 01:16 PM
The set nearest the air filter, or the top are the secondary butterflies.
Twain
BradM is offline
post #9 of 9 Old 11-14-2005, 08:38 PM
Another guy with instructions: http://vstrom.info/cgi-bin/moin.cgi/...ttle_Plates%3f
99% of the work is getting the tank off; overall, pretty easy...
Rick
Semper-V is offline
